It is currently Wed Jul 02, 2025 9:33 pm
PostPosted: Thu Sep 01, 2005 9:11 pm
I figure if I'm going to rebuild my 1275 myself, I'd better get the right tools for the job or know where I can get them. What will I need apart from a good socket and spanner set, and a good torque wrench?
Any other tools that may not be needed, but come in useful for some of those more annoying jobs?
Thanks.
PostPosted: Thu Sep 01, 2005 9:14 pm
vizard's tuning BL's A series long before you start
soft hammer
ring compressor
big protractor (none of this lining up the dots business)
shrugs...
PostPosted: Thu Sep 01, 2005 9:15 pm
A flywheel puller springs to mind...
This place seems to have cheap toolkits...I just bought a kincrome kit off them..:
http://www.transquip.com.au/
PostPosted: Thu Sep 01, 2005 9:22 pm
feeler gauges. gasket scraper. marking tools for when u pulling it down.(match marking things)
PostPosted: Thu Sep 01, 2005 9:26 pm
Primary gear oil seal tool .
You do not want to damage that seal big job to get it all back in and find out you damaged it and pull it all back out.
I swerve and hit people at random.
PostPosted: Thu Sep 01, 2005 9:33 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
bfh to throw across the room when you drop a bolt inside the motor ....
makka
PostPosted: Thu Sep 01, 2005 9:48 pm
What size torque wrench would anyone recommend I get?
Meaning, what torque rating over the maximum tightened part strength should I get?
PostPosted: Thu Sep 01, 2005 9:54 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
dunno what size but get a good one they start at around 300
makka
PostPosted: Thu Sep 01, 2005 10:00 pm
makka
W&B still the best IMO, but I can't afford (I do have their baby 180in/lb one) :wink:
If you must buy a cheapo one the dial & pointer ones are more believable than the cheap clicker ones. Eh, Aaron... :lol:
PostPosted: Thu Sep 01, 2005 10:26 pm
Vernier calipers and a micrometer come in handy too.
PostPosted: Thu Sep 01, 2005 10:31 pm
Loctite.
PostPosted: Thu Sep 01, 2005 11:02 pm
Good set of Ring Openended spannes and Sockets
Torco Engine Assembly Lube
PostPosted: Fri Sep 02, 2005 12:13 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
oh and rachit ring spanners great for them tight places like the manifold nuts
makka
PostPosted: Fri Sep 02, 2005 9:20 am
Die and Tap set to clean the head stud holes and other holes
Valve spring compressor to put the new valve springs on your head if that's what your doing
Feeler gauges
Lots of WD40
That's all I could think of so far...
PostPosted: Fri Sep 02, 2005 3:45 pm
Aviation gasket cement - but use sparingly (you could probably scrape enough of that crap from inside my engine to do 3 others).
Loctite red threadlock (to replace the crumbling metal lockplates.
Buy or arrange to borrow some large sockets for the harmonic balancer and the main bolt (1 5/16" methinks)
Engine lifting brackets
LOTS AND LOTS OF SMALL CONTAINERS OR ZIPLOCK BAGS TO STORE NUTS, BOLTS WASHERS ETC. AND CLEARLY LABEL EVERYTHING IN DETAIL - ESPECIALY IF YOURE GONNA BE DOING THE REBUILD OVER A LONG PERIOD. OTHERWISE YOURE DONE FOR IT - COZ YOU'LL PRETTY MUCH NEED TO STRIP ANOTHER ENGINE TO FIND STUFF YOU LOOSE.
btw getting a cheapo buggered 998 scrap block is not a bad idea either, coz you could strip it for any bolts etc, you might need. Very useful.
