It is currently Thu Aug 07, 2025 10:45 pm
 Post subject: Bad Mini Day???
PostPosted: Wed Aug 24, 2005 2:46 pm
I dunno, maybe I have bitten of more that I can chew or afford with my Clubbie.
Just got a quote of $1000.00 to reuphoslter the front and back seats and fit new headlining and then there will be the cost of a full paint job plus a new vinyl roof.
Also when I drive the beastie I get a lot of clutch shake when moving off and have probs changing up and down through the gears so maybe a new clutch or gearbox might be needed???
Just starting to wonder if it's worth the cost and effort to fix it all up or should I sell it now before I have to spend more.
Or am I just having a bad Mini day and I will get over it??
PostPosted: Wed Aug 24, 2005 3:08 pm
trim pricing is spot on. My trim work set me back $890, and that was front / rear seats only.
PostPosted: Wed Aug 24, 2005 3:32 pm
What's the breakdown on that?
Meaning how much for back seat only?
PostPosted: Wed Aug 24, 2005 3:33 pm
You'll get over it, just go for a drive in a hilly bendy area and you'll soon know it's all worth it 8) Btw you do realise that a vinyl roof is a rust trap and a half?
PostPosted: Wed Aug 24, 2005 3:49 pm
Well Harley, all I can tell you is all the seats will cost $750.00 and the roof lining will cost around $300.00 ..
Trouble with taking it for a drive Wolfman is that it sometimes wont go into gear and makes that horrible crunching sound when I try putting it in to a gear and that only upsets me more... And yep, do know the vinyl roof does cause rust on the roof as there is bit there now but I was told there is certain paint that can be sprayed on before putting the vinyl on and that should stop the vinyl from sweating.
PostPosted: Wed Aug 24, 2005 4:00 pm
Smokie wrote:
Trouble with taking it for a drive Wolfman is that it sometimes wont go into gear and makes that horrible crunching sound when I try putting it in to a gear and that only upsets me more... .
I hear you! That's what JAM was doing, and still is to some degree.
PostPosted: Wed Aug 24, 2005 4:19 pm
Sounds like clutch to me.
PostPosted: Wed Aug 24, 2005 4:59 pm
seat seems reasonable price but my roof lining only cost $130 in velour and it's perfect and beautiful :lol:
67' Matic
73' S
PostPosted: Wed Aug 24, 2005 5:51 pm
I think this one is on the outside :lol:
roof lining not hoodlining I almost assumed that.. :oops:
Roads need more corners
PostPosted: Wed Aug 24, 2005 6:05 pm
Ummm nope, inside one fuzzy... :oops:
