It is currently Sun Jun 29, 2025 1:54 pm
PostPosted: Sat Aug 20, 2005 8:43 am
The kits come with basic instructions and a nice big diagram. It's not too hard to work out, might help if you've got a book aswell. But they are fairly simple.
PostPosted: Sat Aug 20, 2005 9:14 am
13secmini wrote:
thanks for the help people. Anyone know if these kits come with instruction? never opened a SU up before, anything i shouldnt undo or play with?
Plugs in it are NGK BP6ES and there brand new, but are black as the ace of spades :?
Goto 5ES and check your points before you go and buy a kit. Do the cheap things first i always say. I have an SU that is pulled apart you can have a look at on wednesday, or you can have a look at a nice little book i have on them.
Aaron
PostPosted: Sat Aug 20, 2005 9:30 am
Can't argue with advice like that, esp since plugs are ~$15 :wink:
Lillee - 1969 Morris Mini K
PostPosted: Sat Aug 20, 2005 9:27 pm
DON'T UNDO the big nut around the main jet to the body. No need to. If you do you will have to centre the jet again which is a bit of a PITA.
The main jet just pulls out the bottom. Follow the diagram as said above.
Whole job will take about 30 mins.
:idea: Get some carb & throttle body cleaner and use to get all the varnish etc out of the bowl and clean the parts. Cleans alloy up a treat. 8)
PostPosted: Sat Aug 20, 2005 9:34 pm
So Does Oven Cleaner !
If you can get the "Orange" based one, it even smells nice !
J
PostPosted: Sat Aug 20, 2005 11:07 pm
No crap Jim..I'll have to try that...I use Nulon...love it
PostPosted: Sat Aug 20, 2005 11:10 pm
Nulon throttle body and carby cleaner is great 8)
