It is currently Mon Jun 30, 2025 6:54 am
 Post subject: Gear shifter conversion
PostPosted: Fri Aug 05, 2005 7:47 am
I have a 1275cc (which I am boring out to a 1330cc) motor with rod gear change and was wondering if I can change this to a remote gear change off a 1100cc, or would it be better to fit the whole gearbox from the 1100cc, if possible, would this change the ratio etc.
Any comments would be appreciated.
PostPosted: Fri Aug 05, 2005 8:19 am
The shifters are not interchangeable between rod and remote boxes.
If the 1100cc is out of a Mini not a Morris 1100, the internal ratios are the same, except for the diff. Most rod change boxes are 3.44:1, the 1100 Mini K & Clubby were generally 3.647:1. I like this ratio- run 2 of 'em with 1275s.. sounds a bit busy on the freeway though! :lol:
<edit> you would want to keep the pot joints- so just swap the whole 3.44 diff (& pinion) into the other gearbox.
PostPosted: Tue Aug 16, 2005 9:20 pm
Last post deleted.. by GT1310
OMG THANKS!!
I've been looking for cheap viagra for ages.
The amount i use, its starting to cost me a fortune :wink:
willy don't lie! :P
PostPosted: Wed Aug 17, 2005 6:35 am
MOVED FROM conversions the mini mods by GT1310 on 17/8/2005 :wink:
PostPosted: Wed Aug 17, 2005 6:46 am
^^^ *Ignores minor hijack* :roll:
If you can, i would change to remote at all costs.
If you don't want to use the 3.647 diff let me know! :wink:
PostPosted: Wed Aug 17, 2005 9:14 am
Hey Kev, do you really think pot joints are better than hardie spicer joints? or are thay just better than rubber uni's
100% Pure A Series Turbo
PostPosted: Wed Aug 17, 2005 5:30 pm
Pot joints ARE better (according to KC)- he sez they give less power loss and are stronger. Also smoother running, as unlike the old Hardy Spicers they are CONSTANT velocity.
I have a bet each way- Ha-Ha has Mk2 S box with Hardy Spicers, and Barney has pot joints (on a Mini-K box) :wink:
