It is currently Sat Jun 21, 2025 2:27 am
PostPosted: Fri Aug 12, 2005 10:27 pm
Location: thornleigh sydney...round crnr from suzitech!!!!
hey guys,
just interested if anyone would be interested in doing a sought of group buy deal with an engineer???,
i know me and MINIMECHANIC would be interested aswell as CODY n JAM,(interested?)
so who would be interested???
blake (just wondering...would make it cheep for us through one engineer!, all at one time made up!)
:wink:
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE :) yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
PostPosted: Fri Aug 12, 2005 10:49 pm
Yes i would but lol postage :cry: Dam Tasmania :cry: oh well put up a price or something i will have a think about it :wink:
thanks
Blackrz
(998cc Clubman)
- = :Zone 3 Goober: = -
http://photobucket.com/albums/y142/blackrz/?sc=1
"I Live My Life A Quater Mile At A Time"
PostPosted: Sat Aug 13, 2005 12:06 am
will consider....
I have something else in mind at the moment...but will consider
PostPosted: Sat Aug 13, 2005 12:47 am
depends on the dollars...
buggered if my mini isn't going to end up 4efte/g13b/b16a powered before i'm done with it.
PostPosted: Sat Aug 13, 2005 9:46 am
the only problem with this is that most minis will need different frames made up as there not all 100% identical anymore. When Mr enforcer engineering made mine they tried to fit it to another mini and it just didnt line up 100% like it did in my engine bay.
So to do it properly they would have to work out a design then have all the minis there and make them to suit each engine bay. Its still a group buy but just not as easy.
I know the suzuki gti frames can be made to fit all minis, so id say a 4efte frame could be made to fit all clubman minis too, just have to find the best design to do it.
The frame baracade (dean) is getting done now at mr enforcer would probably work as it it made so the motor is fitted and dropped out from under the car. This gives the motor alot more room for adjustments. His going to be soliud mounted (no rubber mounts) but this design can be rubber mounted.
I think if you get 5 people all at once that want a frame made, engine/box fitted with driveshafts your looking at around $2500 still.
1974 Moke - 998cc
PostPosted: Sat Aug 13, 2005 9:55 am
interesting idea if the price is right id be in maybe some people in qld would be interested
PostPosted: Sat Aug 13, 2005 10:17 am
i emailed mr enforcer asking if he would be interested in the idea- at the right price...
Someone should start a website full of aussie engine conversions....
8) 8) 8)
My rides-74 fj40
74 clubman hopefully rego'd soon....
and 76 clubbie van!! - Ratschite after what i found what it was covered in when i found her...
http://photobucket.com/albums/b44/minimechanic/?sc=1
PostPosted: Sat Aug 13, 2005 2:25 pm
if you can get me a price, ill consider getting one :)
PostPosted: Fri Aug 26, 2005 10:01 am
I'm Interested in a subframe. Also how much does Mr enforcer charge for a Gti Subframe for a Clubman. :D
PostPosted: Fri Aug 26, 2005 10:17 am
Same Same - wait on a price - have the motor sitting in Toowoomba(Mum is a legend!!) so if the price is right, I will consider as well
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Fri Aug 26, 2005 12:16 pm
I WILL be making a subframe for the gti mota's soon as I buy one.
I WILL draw it up or make more subframes.
Why in the hell people are asking for 1200 bucks a subframe I do not know.
(unless it is engineered.)
PostPosted: Fri Aug 26, 2005 2:12 pm
Thanks manofaus can you let me know when you do have plans :D
PostPosted: Fri Aug 26, 2005 6:19 pm
meh gti, gimme a toyota motor anyday.
sick of the headaches i've had over the last 4 years with my girlfriends GTi. i've sunk about 3 grand into it, and it's still shagged. latest victim: water pump.
they're really overrated motors.
PostPosted: Fri Aug 26, 2005 7:51 pm
i would be interested.
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
PostPosted: Fri Aug 26, 2005 8:38 pm
not for me.....I am going to build a Charade 3 cyl powered beast. I want to be a bit different.
I will make 2 subframes when I do mine.
