It is currently Mon Jun 30, 2025 2:25 am
 Post subject: Pod filter
PostPosted: Mon Aug 08, 2005 10:29 pm
Okay more for wank/rice/bling value than anythign, i'll be running a pod filter with the supercharger setup.
It will be a cold air type setup with polished pipes fabricated by Exhaust Tech here in Adelaide.
I will be buying my own K&N filter and they will design the cold air system around it, so i'm asking you to decide which filter you like better.
this one or
this one.
I can't decide.
The filter will be pretty much where that big black ducting box is on our clubbies, up near the grille and above the flywheel housing.
Thanks.
Will.
PostPosted: Mon Aug 08, 2005 10:31 pm
Second one...same as the one on my Alfa75 :wink:
PostPosted: Mon Aug 08, 2005 10:32 pm
Got some pics Gaf?
PostPosted: Mon Aug 08, 2005 10:34 pm
NJot at the moment as I need to get my Battery Charger off the Outlaws..so you may have to wait till the weekend :?
PostPosted: Mon Aug 08, 2005 10:36 pm
Yeah i can wait. 8)
The rest... let me know what you think!
PostPosted: Mon Aug 08, 2005 10:39 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
the top one
makka
PostPosted: Mon Aug 08, 2005 10:42 pm
Different view of the bottom one: Image
PostPosted: Mon Aug 08, 2005 10:58 pm
The top one.
Same length but 2/3 of the width of the bottom one, so it takes up less room.
PostPosted: Mon Aug 08, 2005 11:13 pm
It's a clubman engine bay, not a Morrie :lol:
Room isnt really an issue.
The air horns are staying out for good and the cabin air duct is gonna be taken out too.
Its more asthetics than anything... so do you still think the top one?
PostPosted: Tue Aug 09, 2005 4:07 pm
Why not make the cabin air dust a cover for the airhorns??? Not seen can't do ya for em??? :D
PostPosted: Tue Aug 09, 2005 4:27 pm
The bottom one - looks like it flows better too.
The top one looks like one of those KMart Auto jobbies :roll:
PostPosted: Tue Aug 09, 2005 7:42 pm
Another vote for the bottom one. Mounted behind the grill, air has a direct path into the filter.
Do these come with proper bell mouths etc?
I have a unifilter on my GTI, and the intake noise is just awesome! Just like those weber guys go on about...
PostPosted: Tue Aug 09, 2005 7:56 pm
Fatty... the flange mount is 3", so I will be having a cold air setup made with 3" stainless pipe, then up to a flange with a 37mm hole in it, for the inlet on the carburettor.
The filter will not be directly onto the carburettor, as i will be having the pod at the front of the grille and the carby will be pretty much where it is at the moment, but turned 90*.
PostPosted: Tue Aug 09, 2005 7:58 pm
Yeah bottom one will..... nice and thick and chunky... will look the part methinks
I got nuthin......................
PostPosted: Tue Aug 09, 2005 8:19 pm
Go the top one. It's got more bling :D
Ziff
