It is currently Sun Jun 22, 2025 3:05 am
Post new topic Reply to topic  [ 377 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20 ... 26  Next
PostPosted: Sun Aug 07, 2005 9:13 pm
As said move all the leads 180*, or you can turn the drive dog 180* & refit pin (best way, IMO), or pull out the dizzy drive shaft and turn that 180* (but screw a long 5/16" stud in it, DON'T drop it in the motor...!) :shock:
Your call.. :wink:
PostPosted: Sun Aug 07, 2005 10:35 pm
OK Cool, but how do I know if its the right way already or not?
PostPosted: Mon Aug 08, 2005 7:32 am
Normally with the motor at TDC (firing #1 cylinder, ie. both valves on #4 tight) the slot in the driveshaft is pointing to 2 o'clock, with the large offset at top.
Rotor's brass tip should be pointing somewhere around 12 o'clock to 2 o'clock, with a Pulsar dizzy. Put plug lead #1 in cap at that position then work anti clockwise, 1-3-4-2. :wink:
PostPosted: Mon Aug 08, 2005 9:26 am
Thanks!!
Exactly what I needed I think. So I'll try my new dissy cap tonight (old coil plug on it just disintigrated all of a sudden).
PostPosted: Mon Aug 08, 2005 10:49 am
If you can't get enough dizzy adjustment due to vac can fouling the oil cooler hose (for example) just pull the dizzy driveshaft out of the block and move it a tooth or so.
There's nothing sacred about where it points, as long as it all fits and you have room for adjustment. 8)
PostPosted: Mon Aug 08, 2005 4:34 pm
What thread? UNF,UNC?? I assume I just direct the bolt/stud into where the dissy goes, screw into drive thigny, pull out somewhat, twist and put back in??
PostPosted: Mon Aug 08, 2005 4:56 pm
5/16" UNF. I use a rocker stud... :wink:
Correct. 8)
PostPosted: Mon Aug 08, 2005 5:00 pm
Woot! Just in time, Thanks again Doc! :wink:
PostPosted: Wed Aug 24, 2005 1:15 pm
Fitted the pulsar dizzy yesterday and now, after realising i had the body upside down (ran but wouldn't rev), my mini goes smoother than ever. Thorpey says it's fully sick.
Roll Out
PostPosted: Fri Sep 09, 2005 9:07 pm
Hi can anyone please post a pic up or email me a picture of the dizzy modified i understand it all but i just can't get a pic in my mind of how the mini clamp actually goes on the pulsar dizzy :?:
Please thank-you and all the rest
harley
67' Matic
73' S
PostPosted: Fri Sep 09, 2005 9:25 pm
Not sure if I have the ones you need, but there are some in my photobucket
http://photobucket.com/albums/a246/Rampage101/
Also, not sure which page they are on. Sorry
PostPosted: Fri Sep 09, 2005 9:35 pm
Try these pics of my dizzy.
http://community.webshots.com/photo/88347960/297577670RyEODI
PostPosted: Fri Sep 09, 2005 9:46 pm
thanks heaps guys just what i neede :wink:
67' Matic
73' S
PostPosted: Sat Sep 10, 2005 9:38 am
You could go right back to the source and see my pictures:
http://members.tripod.com/%7Emini_digest/dizzy.htm
[email protected]
starchak.ca
tdcperformance.ca
PostPosted: Sat Sep 10, 2005 6:09 pm
hi marcell i had been to your website i was just after a more detailed shot of the finished product
i just couldnt get my head around how the mini clamp went on but know i do 8)
your site is great i was on there looking around last night :wink:
67' Matic
73' S
