It is currently Sun Jun 29, 2025 3:38 pm
PostPosted: Thu Aug 04, 2005 10:40 am
I am wondering if a rod change gearbox will fit into a Morris 1100 with little or no modifications .
What's involved in doing the swap :?: (Apart from the obvious take engine out of one car put in the other :P :roll: )
I know there are some 1100 guys out there....
Thanks
Roads need more corners
PostPosted: Thu Aug 04, 2005 11:51 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
fuzz you just nee to drill holes for the mount and modifi the tunel around the base a bit (reads hit it with a bfh)
makka
PostPosted: Thu Aug 04, 2005 11:53 am
Cool thanks, I thought it might be as for changing over on a mini but I though I'd better check. :D
 Post subject: Morrie
PostPosted: Thu Aug 04, 2005 12:11 pm
So have we picked up a Morris 1100 Arrin :wink:
....better have a look at www.elevenhundred.com :!:
see me if it needs doors :shock: :D
 Post subject: Re: Morrie
PostPosted: Thu Aug 04, 2005 12:38 pm
I'm thinking about it.... Argh too many cars need to find more room.
My little deluxe will be minus his engine (1100 rodchange) and this doesn't have one so I may as well use the 1100 engine for the Morrie. The deluxe will be getting a rebuilt 998 with 1100 crank and remote change gearbox
I found that site when I was looking for info to explain what hydrolastic suspension was :roll: the info they have there is pretty good.
Thanks for the offer on doors I'll see how they look :D
PostPosted: Thu Aug 04, 2005 7:00 pm
The rod change box has pot joints and you will need to change driveshafts to use them.
The rod change will also need to be lengthened a little.
You may be able to get the parts from NZ.
PostPosted: Thu Aug 04, 2005 9:21 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
would it not be possible to use the ends of the mini drive shafts ?????
makka
PostPosted: Thu Aug 04, 2005 9:32 pm
makka
Makka, the inner end splines are different on pot joint shafts to all the others.
PostPosted: Thu Aug 04, 2005 9:40 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
ok cool thanks for clearing that up kev
makka
PostPosted: Fri Aug 05, 2005 6:55 pm
From what I understand you only need one new driveshaft. The long shaft out of a mini becomes the short shaft in the 1100. So you only need the long 1100 shaft. Does that make sense? :P
PostPosted: Sat Aug 06, 2005 12:41 pm
I just worked out it was Steve and Mikey's 1100S :shock: which donated it's 1275 to the moke :(
I did decide to buy it :D
I am now thinking of using one another gearbox I have at home and trying to find a remote housing etc from a 1100. I need a remote housing, diff housing, that rubber sandwich plate thing maybe the mounts and the rod that goes down the centre right :?:
I have an old magic wand box at home, I was told that if you changed over the diff housing then these could be used with a remote change is this correct :?:
If that's the case I'm happy cause I didn't think I would find a use for a magic wand box :D
Yes I realise it will only have 3 syncros. :roll:
 Post subject: Gorilla
PostPosted: Sat Aug 06, 2005 2:17 pm
Arrin...I also have an unmolested grill (the inner part)....what colour is the car and is it drivable :?:
PostPosted: Mon Aug 08, 2005 10:01 am
Car is a white 1100S it doesn't have an engine though :( I will have a spare engine(1100) whilst I am doing up the deluxe though but it really ought to have a 1275 I guess but I don't have the dough for that at the moment I am sorta thinking of pinching the 1275 out of one of my minis and putting an 1100 back in it then possibly selling it..... I don't know but I should really look at getting rid of one of them.
Here's some of the photos:
http://turing.une.edu.au/~adaley/comp515/UNEMC/Gallery_06/gallery.cgi
 Post subject: PM sent...
PostPosted: Tue Aug 09, 2005 10:09 pm
Fuz...PM sent about a spare engine that may still be available for the 1100....ummmm....the man fella is a little "interesting" to deal with :?
Be prepared for a long wait selling the 1100....they don't exactly move real fast. Ken R in the club has had a couple and may be interested in another....also Dave B maybe....then there is always elevenhundred.com...Cheers, Mick
PostPosted: Wed Aug 10, 2005 9:41 am
Nah I'll sell one of the three minis Iv'e got I :D :roll: want to keep the 1100 cause it is something different and I think they are undervalued (both financial and in terms of thier following as a car, but I mean as an interesting and unique car) I don't expect to ever be able to get much for it if I sell :roll: :cry:
Mum also used to own a 1100 when she was young (traded in her Austin seven for one :D) so she might get some fun out of driving it while I don't have room for it down here.
