It is currently Sun Jun 29, 2025 4:07 am
 Post subject: mounting air horns
PostPosted: Sun Jul 31, 2005 12:49 pm
Just wondering how and where people have mounted their air horns? (3 horn type) Anyone got pics of how they've done it?
Thanks
PostPosted: Sun Jul 31, 2005 1:14 pm
Saw this mexican roundie at minishow04 if it helps
All cred to the owner - nicely presented package
PostPosted: Sun Jul 31, 2005 5:09 pm
No pic, but mine (twin Fiamms) are mounted under the LH wheelarch pointing down at front. Keeps the water and crud out....
There was room under there for a Toyota washer bottle & pump, too. :wink:
PostPosted: Sun Jul 31, 2005 9:47 pm
yeah thats where i had mine too
PostPosted: Sun Jul 31, 2005 10:30 pm
I drilled a hole just below where the the grill sits so the horns are facing down and they are sitting behind the grill.
PostPosted: Mon Aug 01, 2005 9:14 am
Mine are in the same place as Aussie16, again, pointing downwards.
Rod Image
PostPosted: Mon Aug 01, 2005 10:08 am
Mine are similar to Kev's but under the right hand gaurd next to the compressor and relay which all tucks in nicely around the fuse box on the top left of the bonnet. I just didn't want to run too many cables in too many directions :oops:
