fuzzy-hair-man wrote:
jill200sx wrote:
So the question now is which master cylinder will give me the best brakes with the Metro 4 pots?
I thought Id be happy with a replacement that keeps a decent pedal, but is there a better option better suited to the 4 pots?
Im happy with no booster.
I just want a pedal that stays firm now
I think it goes like:
The larger the master cylinder bore the more fluid you are moving to your brakes with a certain amount of pedal travel.
Also the larger the bore the harder the pedal will feel
As the metro 4 pots take more fluid to actuate it means for the same sized master cylinder you will use more pedal travel but require less pedal pressure(resulting in less feel).
So I think the answer is go to a bigger bore master cylinder. How big? don't know what size did the metros using the 4 pot calipers use?
Please correct me if I'm wrong anyone...
Isn't the Master cylinder Jill has a twin circuit brake setup? doesn't this change the type of master cylinder she is looking for as well?
Bernoulli's Theorem
How pressure and velocity interact
static pressure + dynamic pressure = total pressure = constant
static pressure + 1/2 x density x velocity2 = total pressure = constant
General Concept:
The Bernoulli effect is simply a result of the conservation of energy. The work done on a fluid (a fluid is a liquid or a gas), the pressure times the volume, is equal to the change in kinetic energy of the fluid.
General Facts:
Where there is slow flow in a fluid, you will find increased pressure.
Where there is increased flow in a fluid, you will find decreased pressure.
In a real flow, friction plays a large role - a lot of times you must have a large pressure drop (decrease in pressure) just to overcome friction. This is the case in your house. Most water pipes have small diameters (large friction), hence the need for "water pressure" - it is the energy from that pressure drop that goes to friction.
Example: the showerhead
A showerhead (if you have a fancy one) has a number of different operation modes. If you go for the "massage" mode, you are moving a little water fast. For the "lite shower," you are moving a lot of water slowly. It takes the same amount of energy to move a little water fast as it does to move a lot of water slowly. This is the amount of energy you have due to your "water pressure."
