scotty wrote:
What is the biggest inlet valves you can use? Can I just put big inlet valves in and leave the exaust valves if they are fine?
With a 202 head, IF you are porting it and reshaping the chambers, Cooper 998 inlet valves (1.219" dia) work good.
Or, you can fit 1.250" race ones or 1.312" Morris 1100S ones. But the latter are around 2mm longer, and so the springs need a washer under. I use 12mm ones. But watch out- the cheapo Chinese washers are too thin.
Exhaust valves- if the valve seats are good, go with standard ones (1"). If they are worn you can fit oversized 1.062" ones (~27mm), or unleaded seats and standard valves.
On big ported 202 heads I have also used 1100S (ie Mk2 S) exhausts turned down to 27mm. Any bigger and they will maybe hit the top of the block..
If running 1100S valves, I leave the (1275) guides up 1.5mm and put 1.5mm packing under the rocker posts.
Before anybody asks, NO- I'm not in the porting business for anybody else. I'm retired (sort of...)
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
