It is currently Sun Jun 22, 2025 2:10 pm
PostPosted: Thu Jul 14, 2005 5:50 pm
Go the toyotas!! :D unbreakable 8)
1974 Moke - 998cc
PostPosted: Thu Jul 14, 2005 7:51 pm
High heel ninja
Brad, i have a mate who rallies a sprinter levin, he would disagree with you about the "unbreakable" part, those TRD rods look pretty poking through the block. :evil:
Doogie
PostPosted: Fri Jul 15, 2005 7:26 am
Doogie
Hehe think he may have to bring his rev limit down, or get a better tune. :D
1974 Moke - 998cc
PostPosted: Fri Jul 15, 2005 8:32 am
High heel ninja
Rev limit is 9,000 rpm,it does'nt go till 5,000rpm because of the cams in it, the engine let go at around 5,500 in 3rd gear curing a rally,
1st event with the "super TRD rods", so he's going back to the standard ones that have never failed. Expensive lesson for him.
Doogie
PostPosted: Fri Jul 15, 2005 8:35 am
Dammit, i've been hijacked! :shock: :lol:
PostPosted: Sun Jul 17, 2005 8:49 pm
just shootin the hijackers
if it was me and there was all this fancy machining going on, rather than cutting a mini crank tail off a crank and welding it onto the 4AG crank, i would hve machined up an entirely new tail that just bolted to the end of the 4AG crank like the flywheel does. not having the measurements and clearances involved makes this sound much easier than it would actually be.
michael
PostPosted: Sun Jul 17, 2005 10:15 pm
michael
Which is exactly how they used to fit Ford BDA etc motors to Mini boxes....
oops! another can of worms opened here... :lol:
PostPosted: Mon Jul 18, 2005 5:26 am
michael
I thought this would be the best way to do it too.
Any idea how the chain drive is tensioned?
PostPosted: Tue Jul 19, 2005 1:35 pm
can't remember :(
PostPosted: Tue Jul 19, 2005 3:03 pm
mickmini wrote:
can't remember :(
Thanks anyway Mick :D
I was thinking it could be setup like the timing chain on A series but my guess is it'd be better having a tensioner setup.
PostPosted: Tue Jul 19, 2005 9:01 pm
You could use a `silent' (Morse) chain, like on the Austin 1800 automatic...
The sprockets are involute shape, like a gear.. probably don't need a tensioner.
Very strong too. 8)
PostPosted: Wed Jul 20, 2005 5:30 am
Very strong too. 8)
To be practical it would have to be easy to get source replacement chains & get a hold of the gears in the first place. Keeping it lubricated would be an issue that you'd need to look at though.
When I first thought about it I was thinking of a belt drive, but i'm doubtful that a belt that will fit (I am thinking 25mm wide) would survive in that application.
The silent chain thing sounds the goods. More efficient than helical drop gears too 8) and if using Austin 1800 bits it'd "keep it in the family" :lol:
EDIT: Found some good info on silent chains (also known as inverted tooth chains) here.
