Downside of forged ones is you need to run more clearance, as they expand more due to the alloy used.
And, they do wear out faster.
I had forged Mahle flat tops in the last 1310 motor. One day at Wakefield Pk one got just a little hot, and seized...
But, I still drove it 120 miles to home... with `single cylinder piston slap'...
I'm now running Hypatec cast ones. Good copy of a Hepolite 21253 type cast piston, but stronger.
<edit> for KC's thoughts on the cast vs forged debate, see here-
http://www.minimania.com/web/SCatagory/ ... ticleV.cfm
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
