It is currently Mon Jun 23, 2025 5:48 pm
 Post subject: gti in roundnose
PostPosted: Mon Jul 11, 2005 9:29 pm
I am looking at buying a 1987 gti suzuki. Where do most people put their radiators? Do you think I could fit it in and get it running in a month? lol...
PostPosted: Mon Jul 11, 2005 9:42 pm
also, i would like to retain the old speedo, has it been done? What sort of heater/demister will fit in the 850?
PostPosted: Mon Jul 11, 2005 11:42 pm
If you have enought money..sure it COULD be done in a month..but i tihnk your dreaming ;)
Again..with enough money almost anything is possible, but i havn't seen the old speedo used with an ECU, you might be able to rig up a sensor or something.
If you don't want to go with the GTi instruments, you can also use something like Autometer guages..
PostPosted: Tue Jul 12, 2005 5:46 pm
I would go with that suggestion. Then it would LOOK a little more original...
 Post subject: GTI in roundnose
PostPosted: Fri Jul 15, 2005 10:43 pm
Radiator in front of gearbox
On the road in a month no
Use mini speedo just recalobrate & use suzuki cable
on gearbox end & mini on speedo head
Blue[/quote]
Keep shiny side up
PostPosted: Sat Jul 16, 2005 3:14 pm
how much of the inside of the engine bay will be modified?
If I am not going to deseam, then perhaps I should leave the engine bay alone too.
 Post subject: Re: GTI in roundnose
PostPosted: Sat Jul 16, 2005 5:16 pm
Blue
[/quote]
Go on Ron, you could do it in a month. You haven't got much on at the moment. :D
Chris
Everything I like is either
PostPosted: Sat Jul 16, 2005 9:33 pm
have a look here:
http://www.16vminiclub.com/gallery/thum ... =61&page=2
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
