It is currently Sun Jun 29, 2025 12:02 pm
PostPosted: Sun Jul 10, 2005 10:41 am
g'day guys, i bought some mini parts a couple of years ago and never got around to deciphering exactly what some of the bits are.
some dont look like mini bits maybe MG or morris 1100 , 1500 etc? can anyone help out?
i've tried to post some pics
thanks in advance.
pete
PostPosted: Sun Jul 10, 2005 11:12 am
I'm no expert but.
Pic 1
Most things look to be mounts of some type :roll:
number 10 could be an oil pickup?
Pic 2
1 looks like a pulley
2 is the badge they put on 1100s
3 looks like heater pipe outlet gaskets
4 could be carby gaskets?
5 door locks?
6 nfi... gearbox bits maybe?
Pic 3
is your timing chain cover.
 Post subject: parts
PostPosted: Sun Jul 10, 2005 2:08 pm
i had worked that much out i'm just not sure what they're from..ie. models, applications etc.
the engine timing cover although an 'A' series motor is different to the ones fitted to my mini engines ive got mine are smooth while this one is ribbed with a small baffle attached to it.
PostPosted: Sun Jul 10, 2005 3:14 pm
there all ex Morris 1100 bits from what i can tell.
Aaron
PostPosted: Sun Jul 10, 2005 4:40 pm
First photo
1,2,3. look a bit like Morris 1100 auto engine mounts (flywheel end)
4,5. I don't know. :lol:
6,7,8 are Morris 1100 engine mounts (timing cover end)
9,10. are oil pickups for the auto gearbox.
Second photo
1. I don't know! It looks like a waterpump pulley but it looks like it has 3 bolt holes and all the Morris 1100 and Minis have 4 holes.
2. Is the tag off the back of the 1100 motor. So it could be Mini K, Clubman (up to 1975) Morris 1100, Sprite, MG Miget.
3, 4. Are carby gaskets for an 1?" SU carb. Number 3. are between the carb and the manifold and number 4 are between the carby and the air filter.
5. Looks like a door lock for the lift up type door handle.(Late K, Clubman, Morris 1300/1500)
6. Is the shaft that drives the foward clutch in the auto.
Third photo
Is the "Australian" timing cover fitted to Minis and Morris 1100s.
PostPosted: Sun Jul 10, 2005 7:36 pm
They are also the same as those used on MG Midgets, AH Sprites and probably Moriis Minors, Austin A30s etc.
Curly
PostPosted: Wed Jul 13, 2005 7:16 pm
im definate that picture 2 number 3 is an air filta gasket , all the other ones i can name i wouldnt know what years they are or model and their pretty much already there
WHERES DR MINI ??????????
My rides-74 fj40
74 clubman hopefully rego'd soon....
and 76 clubbie van!! - Ratschite after what i found what it was covered in when i found her...
http://photobucket.com/albums/b44/minimechanic/?sc=1
PostPosted: Fri Jul 15, 2005 2:27 pm
#s 4 & 5 in the first picture look to be morris 1500 OHC engine mounts
& #1 in the 2nd picture i`d say is a morris 1500 OHC fan pulley
the rest is all as Morris 1100 has said, mostly automatic stuff
easy-peasy :-)
