It is currently Thu Jun 26, 2025 11:58 am
Post new topic Reply to topic  [ 591 posts ]  Go to page 1, 2, 3, 4, 5 ... 40  Next
PostPosted: Sat Jul 09, 2005 2:01 pm
Ok Guys Sini (starlet mini is on the move)
Turbo is so big it can't fit in the front of the motor
It has to go ontop of the gearbox...
Inlet Plenium only just fits.. (sortof) it is so big it will only fit with the fuel rail custom moved above & infront of the plenium instead.
Other then that its all tip top.... Should be finished very soon.
It should be back at home late next week sometime..
Then Off to get the three inch exhaust put under her... & the water to air intercooler fitted up.
Then will disapear for a week to get all wired up...
then back under my garage untill i can afford the custom brakes.
I should have stuck with a stock motor.. To many wallet ache's this way... but i have to live with my mistakes as always... hehehe
Oh yeah Tial BOV has arrived as well... gee its sexy... i will post pics of that tomoz tooo
[img]http://image-cache.boostcruising.com/database/members/files/Baracade20050709134500pslfile1.jpg
[/img]
Baracade
PostPosted: Sat Jul 09, 2005 5:18 pm
Bara that does look impressive
The time and effort you will be able to enjoy the rewards :wink: 8)
PostPosted: Sat Jul 09, 2005 10:58 pm
I like the use of tube bends makes the subframe look very nice. If I had access to one I wanted to go this way. Well done. Also like the polished cover very bling :wink:
PostPosted: Sat Jul 09, 2005 11:00 pm
fark me and the donkey I rode in on.... Thats BLOODY NICE.
:shock:
PostPosted: Sat Jul 09, 2005 11:05 pm
Bara I just noticed that you have the alternator bolted to the subframe how do you keep the tension on the pulley?
PostPosted: Sun Jul 10, 2005 7:22 am
Brad told me yesterday that engine is SOLID MOUNTED! No rubber mounts... :shock: :lol:
PostPosted: Sun Jul 10, 2005 11:28 am
Yeah thats right doc... No Rubber mounts.... No engine movement in anyway...
Yeah means i will get vibration through the car... But less hassle in gear changes when on super high boost.
Baracade
PostPosted: Mon Jul 11, 2005 8:33 am
yep saw it on saturday with dean and must say it is the neatest conversion i have seen yet. All mendrel bent tube frame looks like a proper drag chassis. Engine is solid mounted, it isnt to bad, had a mate with a escort with cosworth turbo engine once solid mounted and was fine.
The inner guards are also neat, nearly untouched. And with the turbo over the box there is plenty of room for a radiator for the water/air intercooler at the front.
The way the frame has been done, dean has to undo 6 bolts and it will drop out from underneath the car :D
1974 Moke - 998cc
PostPosted: Mon Jul 11, 2005 2:24 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
who built the frame ????
enforcer ??
makka
PostPosted: Mon Jul 11, 2005 2:51 pm
yeh Mr Enforcer is doing it. www.mrenforcer.com.au
1974 Moke - 998cc
 Post subject: .
PostPosted: Mon Jul 11, 2005 8:57 pm
Looks good Baracade. How do they do mandrel bends with thick wall pipe?
PostPosted: Mon Jul 11, 2005 9:23 pm
:shock: crap me dead dean thats gonna be a weapon :shock: . the progress is lookin good. its lookin nice as aswell. keep up the nice work and keep us updated :) . i hope its all smooth sailing from here on so it gets done easy 8) .
i like chicken
 Post subject: Mandrel?
PostPosted: Tue Jul 12, 2005 11:37 am
I resized the original pic and lightened it for clarity. That is not a mandrel bend. I doubt as if it's even done with a draw bender.
You can do bends like that with a $200 bender from Supercheap.
PostPosted: Tue Jul 12, 2005 1:28 pm
OK Metalfab its a press bend.
 Post subject: Engine Mounts
PostPosted: Tue Jul 12, 2005 7:16 pm
Brad...the engine is still mounted within your "frame" on those three original large round engine mounts??? That has to provide a good deal of isolation from vibration ?? and the toyota engine is obviously much smoother anyway?? :?:
