It is currently Sun Jun 29, 2025 11:14 am
PostPosted: Fri Jul 01, 2005 10:47 pm
has any one here done an alternitive radiator suport as trying to get those damn back screws in is near impossible
A almost Bog Stock 1977 LS
1969 morris mini panel van, a work in progress
PostPosted: Fri Jul 01, 2005 10:50 pm
I hear you on this one... :twisted:
PostPosted: Fri Jul 01, 2005 11:09 pm
Leave the back screw out of the bottom support bracket- it does f/all..
I've not used one for 10 years! But I do leave the rubber grommet in the bracket.. :wink:
PostPosted: Fri Jul 01, 2005 11:24 pm
Pffff I have no screws in at the moment :lol: except the top mounts...but I was think of attaching the rad to the guard some how...may be some Alloy brackets :idea:
PostPosted: Sat Jul 02, 2005 7:36 am
Gaf I'm talking about the stepped mounting bolts, not the little shroud screws you don't use!! :lol:
If you bolt the rad to the guard, the fan will probably hit the shroud as the engine rocks.. :shock:
PostPosted: Sat Jul 02, 2005 8:05 am
The two at the Bottom...yer they are a pain also....Bugger the shroud ...fling that also.
Just the Rad to the Inner gaurd as is :shock:
PostPosted: Sat Jul 02, 2005 8:29 am
Might overheat in traffic if you fling the shroud.. :roll:
Why not just fit some new 6mm nuts into your (2 core) rad surround and attach it properly. :wink:
PostPosted: Sat Jul 02, 2005 8:40 am
That to difficult :lol: I still need those clips :lol:
PostPosted: Sat Jul 02, 2005 8:52 am
Talk to Greg at Karcraft, he can probably get some.
If not, I can make... :wink:
PostPosted: Sat Jul 02, 2005 9:24 am
There is a mod you can do to the bottom shroud to make it 2 pieces. This allows very easy in and out of the radiator. Involves cutting the bottom shroud into 2 pieces, a pic is worth a thousand words, I sent some to Kev (DRMINI) sometime ago, he may still have them.
You end up with a small part of the shroud (above the bottom hose) that remains attached to the rad by the screws. The other part of the bottom shroud is set up to be bolted to the engine via the bottom mount in the normal fashion. There is a strengthening bracket under this shroud (that bottom bracket bolts to) that you DO NOT cut thru. This strengthening bracket is used to locate and support the other piece of the shroud on the radiator. A couple of locating lugs are needed here to allow this to work.
Before separating/cutting the shroud, find the spot welds on the strengthening bracket on this end and drill these right thru with approx 1/8" drill. These will be for your locating lugs. I have used machine screws about 3/8 - 1/2" long welded to the underneath of the strengthening bracket to protrude upwards. You may need to clearance the holes in the other piece of the shroud to allow it to sit over these screws/lugs, which should make the shroud sit back together as 1 piece again.
All that is needed now to remove radiator is - top and bottom hoses engine end (top hose your choice), loosen fan belt, top mount and bottom 2 shroud screws at the front of the car. Presto, rad can be lifted out.
Hopefully Kev can post pics, all will become clear.
Steve
PostPosted: Sat Jul 02, 2005 10:48 am
Steve it was a while ago- not in my pics now and I've probably deleted them from mail.. can U send again please..?
:wink:
PostPosted: Sat Jul 02, 2005 7:36 pm
Here are Steve's pics of this rad shroud mod...-
PostPosted: Sat Jul 02, 2005 7:42 pm
I'll have to have a good look at my spare tomorrow morning...It maybe the first mod I do for the Van...LOVE the Idea :wink:
PostPosted: Sat Jul 02, 2005 7:56 pm
Thanks to Kevin for posting the pics. To make this mod successful and hassle free, it is important to ensure the engine piece of the shroud lines up with the rad on installation. Some bending of the 3mm steel monting bracket may be required. What you want is this part of the shroud sitting in the right place to line up with the rad when you put it in, not at an angle that puts pressure on the 2 piece shroud or the rad.
I have down this mod to my minis for some years now (inc race mini) and never had a problem.
Given the pain in the ##se job removing the rad normally is, getting a rad in and out with this mod is an absolute pleasure and still amazes me how easy and trouble free a job it is now. :wink:
Enjoy!
PS - every person who uses this mod must send me $5.00 :D
Steve
PostPosted: Sat Jul 02, 2005 7:57 pm
this definatly looks like the way to go
will see about doing it soon as it looks like the motor may be coming out soon any way
