It is currently Sun Jun 29, 2025 2:25 am
 Post subject: rear discs
PostPosted: Fri Jul 01, 2005 8:59 pm
ne ideas? Perhaps some smaller solid discs and falcon calipers? (the falcon calipers have intergral handbrake mechanism)
not KAD type, but something to suit my camira option for the front.
PostPosted: Fri Jul 01, 2005 9:07 pm
If you use the search button you will find a few threads where people have asked about rear discs.
I would advise against rear discs as too much effort for too little gain but that is just my view :wink:
I had an XF Falcon with rear discs and the integral handbrake is a pain as it has a habbit of seizing up (sometimes in the off position but most often in the on position!)
PostPosted: Fri Jul 01, 2005 9:14 pm
Yeah my EA Falcon did the same, I changed both sides..
Falcon calipers would be way too big anyhow..
Fiat 124 or 125 rear calipers were similar design but smaller and their handbrakes didn't seize. Better mechanism.. :wink: But the handbrake was pissweak.
Most cars made now with rear discs have brake shoes inside the disc.. so the handbrake actually works! :lol:
PostPosted: Sat Jul 02, 2005 12:30 pm
If you really want to up the stopping power of the rear brakes, just fit some Superfin drums if you REALLY want. Discs on the rear is a big waste.
Jonathan
PostPosted: Sun Jul 03, 2005 10:26 am
Mano,
Cant see the point really with less than 300kg at the rear, why need huge brakes. All you will get is contsatnt wheel lock unless you use a very sensitive biasing valve which equal more $$.
Superfins yes, discs??
Andrew
Users browsing this forum: No registered users and 24 guests
