It is currently Mon Jun 30, 2025 5:25 pm
PostPosted: Tue Jun 28, 2005 8:01 pm
Hi All,
I'm wondering if it is possible to fit a set of Sports pack arches ona Mk2 mini, with the external hinges. I've seen many minis with internal door hinges with them but none with externals.
Will the guards or hinges need any modifications so they will not interfere with each other or will they fit sweet with no mods?
Any help or advice would be greatly appreciated.
Phantom.
PostPosted: Tue Jun 28, 2005 8:04 pm
from my pictures of sportspacks i think they would interfere with the hinges.
i am sure you can cut them so they merge together but im not sure on the look of this
not too clear but you see how far back they go
heres the rear
Inconspicuously Conspicuous
PostPosted: Tue Jun 28, 2005 8:09 pm
It does interfere. You wouldn't need to cut much out though.
 Post subject: .
PostPosted: Tue Jun 28, 2005 8:12 pm
sc850 has them on his I think. You do need to cut the guards not sure about the hinges
PostPosted: Tue Jun 28, 2005 8:13 pm
Thanks for the reply's, I kind of suspected they would interfere, but without having a set to to measure up with, I wasn't sure.
If anyone has fitted these to this model, I'd love to see how they fit.
Cheers.
PostPosted: Tue Jun 28, 2005 8:26 pm
Here's a pic taken at Minishow. I've left it big so you can zoom in and see how much.
PostPosted: Tue Jun 28, 2005 8:27 pm
oh they look heaps tuff there!
PostPosted: Wed Jun 29, 2005 12:58 am
Yep, mine needed a 10mm cutout to allow the lower door hinge to fit under the arch. Other than that, they are fine.
Sorry, no pics of mine.
PostPosted: Wed Jun 29, 2005 1:12 pm
A turbo mini at the mini muster had a zee max kit on and he had to cut the hinge holes out and it still looked tuff.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
