It is currently Sat Jun 21, 2025 8:09 pm
PostPosted: Sun May 25, 2025 9:30 am
My passenger side windows are rather difficult to wind down on my 1969 Mini K.
I thought at first it could have been the door frame being a little out of whack, but after tweaking it the door frame with a large bit of wood - its still very difficult to get wind down.
Interestingly, widing up isnt too bad (guessing the spring helps).
Any ideas on what I should be checking??
PostPosted: Sun May 25, 2025 10:12 am
Spray the runners with silicone spray.
PostPosted: Sun May 25, 2025 10:28 am
It may be that the regulator is clogged with old hardening grease or it may be the runners.
Silicone spray does not always help, one of my drivers side was difficult and silicone spray made it a bit worse but when I wiped all the silicone off it actually improved.
Cheers Dave.
PostPosted: Sun May 25, 2025 11:14 am
Did you replace the bailey channels? That seemed to make my last one very difficult. I didn't notice it being difficult until after they were replaced.
Too many minis
PostPosted: Sun May 25, 2025 9:50 pm
Ok, so I'm going to so say I think its a combo of all 3.
I did replace the bailey channels on the quarter light frame (around 1.5 years ago) , and thats when I first noticed the difficulty winding the passenger window. I had left it because I'm the driver and main priority was sealing the car from water.
I sprayed the bailey channels with silicone spray, not sure that did a lot but possibly helped.
The main thing was to remove the whole regulator assembly and spray degreaser and clean through the gear / winding mechanism.
Its still not 100% but better than before.
Quarter light on the other hand is a decorative feature.. I think I might have inadvertently bent the hinge - the glass fowls the window frame without a bit of force. (oh well - at least passengers now have fresh air via the window)
PostPosted: Mon May 26, 2025 10:10 am
Graphite powder works better than silicone spray, and doesn't attract and hold dust.
;-) Pete...
____________________
1968 Deluxe 1275
1969 Deluxe 'Scruby' 998 Looking for a roof skin...
PostPosted: Tue May 27, 2025 3:59 am
Yep graphite powder was what we used back in the day.
PostPosted: Tue May 27, 2025 12:06 pm
I did replace the bailey channels on the quarter light frame (around 1.5 years ago) , and thats when I first noticed the difficulty winding the passenger window. ....
Just a thought: when replacing the quarter light frame back into the door (with new bailey channel), has it been fitted a bit to one side, pinching the window glass a bit?
Maybe loosen the 2 big hex-headed self-tappers (and also the 3 small self-tappers holding the top of the quarter-light frame) to see if you can get a bit of free play for the glass.
