It is currently Fri Jun 20, 2025 9:15 pm
 Post subject: Door hinges (Again!!)
PostPosted: Tue Jan 07, 2025 12:27 pm
I do not want to piggy back onto the other thread, so having bitten the bullet I have the top drivers hinge off. First thing is the actual hinge looks bent down at the pivot point, that is the hinge is not aligned and when it opens it really gets out of line. The problem is there is a gap at the top front of the door that cannot be fixed by adjustment. The hinges felt worn when on the car but now one is off it actually is not really worn or loose but the bend worries me.
The other problem is the the pin is not coming out, I have knocked out many and various pins in my time but this one is not gonna move.
Cheers Dave.
PostPosted: Tue Jan 07, 2025 4:14 pm
Might need to replace it with a new one. I recently bought 4 new hinges from Minispares - not cheap but sooo much cheaper than Aus distributers
PostPosted: Tue Jan 07, 2025 4:39 pm
Are they the alloy ones, I would be interested in how durable thay are compared to the original steel ones.
Cheers Dave.
PostPosted: Tue Jan 07, 2025 7:32 pm
I spent 10 mins trying to drive out the pin and it did not move at all. I tried both ways just in case. The upside is that I refitted the hinge fine as nothing had moved. The hinge must definitely be bent as at full upward movement of both adjustment and the hinges play the door is still out by a good 15mm at the top front.
Cheers Dave.
PostPosted: Tue Jan 07, 2025 8:05 pm
Originals were cast iron, not steel. They just break in a good prang.
I have a spare top RH one off my car which I have repinned and bushed, send me a PM if interested.
Note I am not doing these anymore, I am too old and retired.
PostPosted: Wed Jan 08, 2025 10:48 am
I am lucky in having more than one mini (although SWMBO has different views on the situation). I have removed the top drivers hinge off another car and a number of things became clear.
Firstly I can now remove a hinge in less than 10 mins. ;-)
Secondly the hinge on the main car is most definitely bent down at the the tongue as I suspected.
Further more the hinge I have just taken off the second car is seriously worn. The holes in the fork part are so flogged out that a new pin literally falls straight through. It had a new pin in it already which is not worn at all. I am going to make an oversize pin to see how big it needs to be and I will ream a bush to suit if it is not too far gone. If I have to turn a new bush I will. This will preferably be put back on the second car.
I have a set of supposedly good used hinges coming and I have pins and bushes so I will pick the best option for the main car.
Cheers Dave.
PostPosted: Thu Jan 09, 2025 7:05 am
They appear to be an alloy. I havent fitted them yet (need to get them painted), but I would imagine they wouldnt be as robust as cast steel.
PostPosted: Thu Jan 09, 2025 8:14 am
The early ones were brass. They wear pretty easily but they are also quite easy to repair, compared to cast iron.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Thu Jan 23, 2025 8:02 pm
Well for the first time in ages I have a properly fitting non drooping dr8vers door. Second hand hinges which I rebushed and pinned, painted and fitted. I had known for a.while that the original hinges were worn but what I didn't know until I removed was that the top hinge was bent down at the tongue.
The problem was that there was a gap at the top front between the door and the seal enough to let water etc in.
There are however 2 minor problems, the painted hinges look too dark and shiny and the door is if anything too far forward now. I will.see if it adjusts if it bothers me too much.
Cheers Dave.
PostPosted: Sat Jan 25, 2025 1:44 pm
This is for Timbo as I can't email him
PostPosted: Sat Jan 25, 2025 8:48 pm
I've got an alloy set, but the front set screw of one stripped the thread when tightening, hardly any tension on it .
I re bushed and pinned my original ones.
I also have some original steel sets.
PM me if anyone is interested, and I'll check the condition.
RGDS Stewart
Mk 1 Cooper S 1965
If you could erase all your mistakes of the past
You would also erase the wisdom of your present
Remember the lesson not the disappointment.
PostPosted: Sun Jan 26, 2025 8:48 am
I decided to adjust the door to try and get a better fit and ended up messing around with it for way too long. I have come to the conclusion that the door is a poor fit in the frame as I can get it OK and the door closes well but It is less than perfect. I suppose a 50 year old car may have alignment issues.
Cheers Dave.
Users browsing this forum: Google [Bot] and 88 guests
