It is currently Sat Jun 21, 2025 11:45 pm
 Post subject: Eyeball vents
PostPosted: Mon Jan 20, 2025 8:25 pm
I am hoping that someone on here can provide some information for me.
I am restoring a 1982 Range Rover Classic and it has two eyeball vents in the dashboard.
One of them is complete and works OK, the other is missing one of the flaps that shut off the air flow and most of the other flap is broken away.
As these were common for cars in the 70’s and 80’s I thought some parts may be interchangeable.
The bore of the eyeball is approximately 40.5 mm.
The flaps are driven by a bevel gear on the centre shaft that meshes with similar gears on the flaps.
Can anyone confirm if the bore of the later mini eyeball vents are the same and if they operate the same way.
 Post subject: Re: Eyeball vents
PostPosted: Tue Jan 21, 2025 7:30 pm
Visually they look similar and operate the same, but the main bore of the vent through the middle on a mini one is 56mm.
PostPosted: Tue Jan 21, 2025 7:37 pm
Thanks Harley, but the Mini One is a BMW Mini isn’t it.
I was thinking of the original mini that had the flat dashboard in the UK.
I believe these had the two eyeball vents.
Phil
PostPosted: Tue Jan 21, 2025 10:46 pm
Phil
Harley means the vent from a classic mini not a model of BMW mini.
I hadn't got around to measuring one but my guess was that the classic mini ones are larger than your 40mm measurement.
Too many minis
PostPosted: Thu Jan 23, 2025 10:41 pm
I measured a classic mini vent from a 90s model car.
For reference though - a BMW mini vent is 65mm through the middle for an R50/R52/R53.
PostPosted: Fri Jan 24, 2025 8:03 pm
Thanks Harley
Strewth, at 56 mm the bore of the eyeball is huge compared to my Range Rover at 40 mm.
Phil
PostPosted: Sat Jan 25, 2025 1:37 pm
Probably because they aren't fed air from a fan. The eyeball vents in minis were only ever connected to ducting that ran to the grille.
I guess if the hole was much smaller you'd barely get any airflow.
PostPosted: Wed Jan 29, 2025 4:40 pm
I came across this cool website called Carsized that allows you to compare the sizes of two different cars. Just for fun, here's a 1985 Range Rover next to the current MINI Countryman.
https://www.carsized.com/en/cars/compare/mini-countryman-2023-suv-vs-land-rover-range-rover-1985-suv/
It's no wonder the MINI stuff is big.
Sorry this doesn't help your vent question.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Wed Jan 29, 2025 7:56 pm
While also not related to the vent question here is another comparison photo.
Phil
PostPosted: Wed Jan 29, 2025 8:22 pm
Physical size is not everything. Good things have always come in small packages to quote a cloche.
Cheers Dave.
Users browsing this forum: No registered users and 119 guests
