John Smidt wrote:
I probably should not have added this to the bottom of this thread, But I must admit I am not sure how to start a new thread and add a quote from another thread,
Sorry about That Simon
You should get Gerg or Scotta74 to earn their keep and teach you instead of making the coffee's
To start a new thread just use the "new thread" button to the left of the "post reply" button at the top or bottom of the screen. Don't forget to add a subject line.
To quote someone is a bit harder. You hit the quote button on the post within the thread that you want to quote. The bit that appears within the square brackets between the quote and end quote comments will appear as a quote. You can delete/edit that quote provided you don't delete the square brackets or their contents themselves. To add a quote from another thread entails copy and pasting the words and adding the quote /end quote in square brackets in the appropriate places. Not too hard, but requires a bit more understanding of the HTML language that works behind the scenes.
Sounds hard, but I'm sure the boys could show you and it will seem a lot simpler than it sounds.
KB
