Just after some feedback. I'm not trying to re-invent the wheel, but keen to try another ignition system on the Cooper S having read a fair bit about whats available - lumenition, petronix, accuspark, 123, Peak, CSI, black box etc. etc. I did run a Allison optical ignition (Opto xr700) on my first Cooper S >40 years ago with no problems. I still have it in a 25d.
Over 12 years ago, I converted the Dino from its original points & Dinoplex CDI ignition to Lumenition and Bosch igniter & coil (thanks to Adrian on Ferrarichat, who developed the concept for Dinos -
http://www.dinoplex.org). It has made the car start far easier (especially starting when hot - airbox weber heat soak - a known inconvenience) and more tractable when cold. I will endeavor to adapt this system to the mini. Most of the parts used then will be the same again this time, except for the chopper wheel (Lumenition 201687 chopper or fk116 25d fitting Kit). The Bosch controller will mount on a bracket(heat sink) in the holes originally for the front bracket mounting the earlier lockheed booster, so no new holes. A separate fused power feed from the solenoid will power it, through a relay triggered by the ignition switch/ignition wire.
The same Bosch controller unit has been used in various Audi, BMW, Porsche & VW's. Its a high power ignition controller featuring electronic dwell management, current limiter/control and a tacho output. I see the same Bosch controller is used in the Ford BDA/D/G Performance ignitions' scorcher package. The lumenition Optronic OS50 optical pickup is used in lumenitions' kits.
I've just started sourcing the parts (again) and dismantling the 29D distributor for conversion. I know the concept works very well (7800+ in the v6), but have I missed anything in the mini situation? Is it overkill?
I realize at some stage, I will have to get the advance curve modified to suit the motor. Should be a fun project and far less daunting than taking a leap of faith and cutting up a Ferrari distributor points backing plate years ago. Just have to build a motor, do the body work, paint the car, assemble it and run it in before I can try it ..... (I do have a spare intact 29d distributor as a "fail-safe")
