It is currently Fri Jun 27, 2025 10:41 pm
PostPosted: Sun Jun 16, 2024 4:39 pm
Hi Brains Trust. I’m installing a new wiring loom on a 1966 mk1 and wanted to know where the headlight wires are routed through to the engine bay? Is there a particular opening with grommets? Is this the same on both sides? Do the indicator wires wrap in with the headlight wires before they are routed through? I’ve search countless videos and pictures but just can’t find where these are run? Pictures would be amazing!!! Thanks…
PostPosted: Sun Jun 16, 2024 5:32 pm
There's a gap in the panels at each corner that they go thru. No grommet or anything. I think the indicator wires are separate but thru the same spots.
Too many minis
PostPosted: Sun Jun 16, 2024 7:50 pm
Thanks. Is that in the top corner between the front panel and side panel? It looks to be a very small gap right at the top of the panel? Is that correct.
PostPosted: Sun Jun 16, 2024 8:41 pm
Just behind where these red circles are.
Too many minis
PostPosted: Mon Jun 17, 2024 7:06 am
Wonderful. Thanks so much.
PostPosted: Mon Jun 17, 2024 2:56 pm
