It is currently Sun Jun 22, 2025 9:06 pm
PostPosted: Wed May 08, 2024 1:42 pm
I have designed various 3D printed tools and items to help me out during my Mini restoration and since 3D printers seem ubiquitous, I thought it would be great for the community to have a thread where we can share links. If you have your own, or find any designs that you'd like to share, please post them.
Some of my designs (from my Printables profile https://www.printables.com/@Mearcat/models) :
Door clamp - This tool helps hold the door while fitting/adjusting them. Suits wind-up and sliding window models
https://www.printables.com/model/250164-classic-mini-door-clamp
Panel gap tools - Simple tool for setting car panel & door gaps
https://www.printables.com/model/244897-car-panel-gap-gauge-tool
Rear quarter window sanding block - Sandpaper holder for sanding quarter window post-rust repair
https://www.printables.com/model/696693-classic-mini-rear-quarter-window-sanding-block
Flexible sanding block - for sanding car panels or anything curved
https://www.printables.com/model/505709-flexible-sanding-block
Door hinge templates for aligning hinge holes new A-panels
https://www.printables.com/model/871604-classic-mini-external-door-hinge-templates-for-a-p
-Alan
PostPosted: Wed May 08, 2024 1:51 pm
Online
Fantastic Alan, I have made heaps of special tools for the minis but never 3D printed ones.(Puts hand up as a 3d printer Ludite).
Thanks for sharing.
Cheers Dave.
PostPosted: Wed May 08, 2024 2:14 pm
Some others I've found while searching for Classic Mini related prints (I can't of course guarantee that any of these will work, or match your model Mini)
SU HIF44 Air Cleaner Elbow
https://www.thingiverse.com/thing:5733101
Gauge holder allow extra gauges to be added to a Cooper S 3 clock binnacle
https://www.thingiverse.com/thing:5913417
Seat Belt cover
https://www.thingiverse.com/thing:3018522
Centre binnacle extension piece for a tachometer like the old Broadspeed type
https://www.thingiverse.com/thing:4710094
Case for a 12v power adaptor which fits in the ashtray space in the upper dash pad
https://www.thingiverse.com/thing:1638494
Gearbox spring and ball tool for synchronizer assembly
https://www.thingiverse.com/thing:3838125
or
https://www.thingiverse.com/thing:5371649
Gearbox Double Roller Bearing Removal Spacer Tool
https://www.thingiverse.com/thing:3838110
Wheel Bearing Installation Tool - install the outer rings of new wheel bearings for disc type minis
https://www.thingiverse.com/thing:3838122
Clutch Slave Filler - Pre Verto versions
https://www.thingiverse.com/thing:6531954
Sun visor mounting brackets
https://www.thingiverse.com/thing:5324057
Demister vent
https://www.thingiverse.com/thing:5371986
Starter motor plug - magneti marelli pre-engaged starter
https://www.thingiverse.com/thing:4942483
Door lock plinth/surround
https://www.thingiverse.com/thing:4940208
Clutch oil seal tool
https://www.thingiverse.com/thing:4600947
Phone holder (replaces dashpad ashtray)
https://www.thingiverse.com/thing:2203204
LHS heater tube
https://www.thingiverse.com/thing:3969645
CZH628 B-pillar striker blanking cover plate
https://www.thingiverse.com/thing:4680972
123ignition electronic distributor seal
https://www.thingiverse.com/thing:4841962
Cup holder - attaches to front seat bracket
https://www.printables.com/model/480988-classic-mini-cup-holder
Steering column indicator/blinker holder
https://www.printables.com/model/859028-classic-mini-blinker-holder
String method clips for DIY toe check
https://www.printables.com/model/757603-classic-mini-string-method-tracking-front-clips
-Alan
PostPosted: Sun May 12, 2024 9:58 am
Milatsmadmini
Seat Belt cover
or
Demister vent
LHS heater tube
Some good ones in there that i hadnt come across! Awesome stuff.
I made an entire set of dimple dies with 100% infill (took 40h of printing) but worth it.
Other stuff like vice jaws and small tool holders has made working in the shed that much nicer.
PostPosted: Sun May 12, 2024 11:48 am
Does anyone with a 3D printer have the capacity to print me a few things at my cost?
PostPosted: Mon May 13, 2024 9:02 am
I have a few others that aren't up anywhere if anyone needs them too.
Nick
PostPosted: Mon May 13, 2024 10:25 am
Milatsmadmini
anyone drawn up a mk1 cowling in CAD?
PostPosted: Mon May 13, 2024 2:24 pm
Milatsmadmini
Yeah potentially Timmy, what are ya after?
PostPosted: Mon May 13, 2024 2:48 pm
The 3D printing topic now has its own folder - viewtopic.php?f=65&t=102302
PostPosted: Wed May 15, 2024 10:22 am
I’ve made my own stl file and trying to refine the design. I’d also be interested in one of the ram pipes linked above
PostPosted: Fri May 17, 2024 12:23 am
If anyone is interested in this stuff this guy is really cool https://www.youtube.com/@MakingforMotorsport
He builds his car for competitive motorkhana
