It is currently Mon Jun 23, 2025 12:59 pm
 Post subject: ignition coil and cover
PostPosted: Fri Apr 12, 2024 12:02 am
The YKG2S2 that I'm working on still has the original coil stamped 05-67. Should I keep this on the car or as a souvenir and use a modern coil i.e. epoxy filled?
PostPosted: Fri Apr 12, 2024 8:02 am
I’d check the resistance in the primary and secondary circuits, if those are ok and the engine runs fine I’d be ok with using the old one. Having a spare one in the boot for long trips probably isn’t a bad idea
The primary should be about 3 ohms on a Mk1
PostPosted: Fri Apr 12, 2024 8:24 am
The primary resistance should be around 3 ohms on your coil.
I would get a new modern coil and keep the old one for posterity.
Cheers Dave.
PostPosted: Fri Apr 12, 2024 2:17 pm
Use the old one.
Too many minis
PostPosted: Fri Apr 12, 2024 3:49 pm
68+86auto wrote:
Use the old one.
I agree, oil filled last for life of the car really, epoxy filled are crap.
Pertronix and Bosch both have or had problems. Look at the short life of many modern coil packs for example. Epoxy filled.....
I like NGK oil filled coils. Or any other oil filled one really.
PostPosted: Tue Apr 16, 2024 5:20 pm
Thanks all for your input.
Regards Brian
PostPosted: Tue Apr 16, 2024 5:42 pm
Is it a HA-12 or SA-12?
