It is currently Wed Jun 25, 2025 1:57 pm
PostPosted: Thu Apr 11, 2024 10:56 am
My Mk2 Cooper S has an odd number *9F/XE/Y53xxx*H
I am now in the process of getting registration in NSW and the RMS called at my home today for an inspection. It was very interesting. One of the RMS guys said that Higginbottom back in the day added an 'H' to the engine block when they worked on an engine. As they appear to be out of business, I cannot verify this new information.
PostPosted: Thu Apr 11, 2024 11:01 am
Surely he pulled that out of his bum...
PostPosted: Thu Apr 11, 2024 11:15 am
:shock: I don't think that comment was very helpful.
PostPosted: Thu Apr 11, 2024 3:08 pm
Does the H look original as in the same as the rest or does it look added?
Cheers Dave.
PostPosted: Thu Apr 11, 2024 3:50 pm
I remember a reference somewhere for this years ago but now not sure what..!
Did the block have liners originally maybe?
PostPosted: Thu Apr 11, 2024 3:55 pm
One of my cars has an "S" suffix to the engine number which indicates a factory installed sleeve to one or more cylinders. Mine was 1.
PostPosted: Thu Apr 11, 2024 9:38 pm
Like drmini, I also seem to remember a past reference to an extra letter.
Did the "H" stamp added to the engine number have anything to do with the removal of the metal tag fitted from the Uk with the engine number?
Local regulations required the engine number being stamped directly onto the block and not just on a removeable tag.
PostPosted: Thu Apr 11, 2024 10:40 pm
Bill B The 'H' was added.
PostPosted: Fri Apr 12, 2024 12:29 pm
I'd go with the RMS in your original statement then. It's obviously been added later.
PostPosted: Fri Apr 12, 2024 12:40 pm
They are not part of the engine number.
PostPosted: Tue Apr 23, 2024 8:01 am
The RMS has now informed me that the 'H' has to be included in the registration papers.
PostPosted: Thu Apr 25, 2024 5:43 pm
"The RMS has now informed me that the 'H' has to be included in the registration papers."
I would suggest this is obvious....
The documentation has to match the car ...and VV.
All early Ss came with UK engines which had the engine number on a plate. These were removed by the factory during the build and the number was stamped on the block. The factory would then attach the plate with a bit of thin tiewire to the upper rad hose. Can't say they "always" did it but I saw quite a few so fitted..
My S was UK built so the chassis number is also on a plate. Rego would not accept this but allowed me to choose a number for the paperwork from those "permanent attached" to the body. The UK factory spot welded two plates onto the body; an FE number and the body number. I chose the body number because this appears on the Heritage Certificate.
Cheers, Ian
PostPosted: Fri Apr 26, 2024 8:19 pm
Rego was completed today == HOORAY
PostPosted: Fri Apr 26, 2024 9:52 pm
Congratulations!! :mrgreen:
