It is currently Wed Jun 25, 2025 2:38 am
 Post subject: Clubman GT gauge cluster
PostPosted: Thu Apr 11, 2024 4:34 pm
How does the plastic part of the gauge cluster attach? mine is loose it does not want to stay in place is it mounted by screws?
1973 Clubman GT - YG2S8 1637
PostPosted: Thu Apr 11, 2024 5:54 pm
If you mean the outer housing then it uses clips with teeth that grip in a slot in the housing. I can try to get a photo 8f you need it.
Cheers Dave.
PostPosted: Fri Apr 12, 2024 9:40 am
That's what I mean, thanks, appreciate it
