It is currently Mon Jun 23, 2025 12:13 am
PostPosted: Wed Mar 27, 2024 1:12 pm
My speedo needle waves around, so I have no idea of my speed.
Is there an easy fix?
PostPosted: Wed Mar 27, 2024 1:42 pm
How much does it wave around?
Make sure both ends of the speedo cable are tight.
Too many minis
PostPosted: Wed Mar 27, 2024 2:21 pm
I'd say 10 to 20 MPH.
I have checked cable tightness.
PostPosted: Wed Mar 27, 2024 5:50 pm
Mine does this too, on mine it's the friction to turn the odometer wheels of my old Moke 140kmh speedo.
When the ratchet pawl engages the wheel, the needle drops, as it retracts the needle rises.
I need to pull the speedo out and lube the bits but haven't got a round tuit.
PostPosted: Thu Mar 28, 2024 10:30 am
Can also be a sign the cable is sticking in it's sheath, had two fail a few months after showing this symptom.
Both had burns from getting too close to the headers.
PostPosted: Thu Mar 28, 2024 6:40 pm
another cause is that the magnet plate that's driven by the speedo cable lightly touches/drags on the cup that the needle spring is attached to - there's a little bush under it that wears, when it does that the clearance is reduced and the needle jumps around....
new cable first!
PostPosted: Mon Apr 29, 2024 3:39 pm
New cable on the way. Will advise results.
