It is currently Tue Jun 24, 2025 5:03 am
 Post subject: Radiator Drain Plug
PostPosted: Tue Feb 06, 2024 4:48 pm
Hi - does anyone have a photo of the original 72 Australian radiator drain at the bottom?
Attached is a photo of mine which looks to have the head sheared off? Does it look like the original Radiator? Cheers
 Post subject: Re: Radiator Drain Plug
PostPosted: Tue Feb 06, 2024 4:57 pm
This is the drain plug on my 1970 Cooper S.
Is the brass ID plate still soldered to the header tank? If so what is the part number. I can check parts lists to confirm.
PostPosted: Tue Feb 06, 2024 5:17 pm
Thanks for that! Mine certainly looks similar, but the plug is rogue/unuseable.
Mine has no ID plate. Thanks again.
PostPosted: Wed Feb 07, 2024 7:04 am
I do not know the dates but there was one with a small wing nut type tap affair set in larger plug, then there was just the plug as you have shown.
Cheers Dave.
PostPosted: Thu Feb 08, 2024 8:10 pm
just a 1/8 BSPT blanking plug at Pirtek etc. if you're chasing one
