It is currently Tue Jun 24, 2025 9:57 pm
Post new topic Reply to topic  [ 170 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11, 12  Next
 Post subject: Re: WIRING GETTING HOT
PostPosted: Tue Jan 16, 2024 8:55 am
1071 S Ian, when your drowning and have no electrical prowess, you clutch at straws, know what I mean?
PostPosted: Tue Jan 16, 2024 9:53 am
Cooperess
We were all trying to throw you lifebouys, but I think that many of them were out of your reach.
The trouble is that now we want to know what the problem was, and the solution.
Invest your $179 in an auto electrician and let us know.
Dave2
PostPosted: Tue Jan 16, 2024 10:01 am
1071 S wrote:
cooperess wrote:
1071 S I'm with you after the checks I have tried. If the short is in my new wiring loom after the numerous times I have heated it up, then all the tape needs to be removed or is there a simpler way?
Maybe I need one of these?
https://www.endeavourtools.com.au/ETPPB ... robe-basic
For why?.... Why on earth would you pay $179 for a test light when you can get one from any auto supplier for about (I would think, not having bought one for years) ten bucks.... Or make one from scrap ...a few lengths of spare wire, an alligator clip, a spare tail light bulb and an old screwdriver....
And, if you don't have a test light, then you really need one...
Cheers, Ian
It is NOT a test light but I do agree it is unnecessary and overpriced as I have already posted. It is designed to be able to quickly supply + or - to something to test it. Not something that is useful in this situation.
A power probe doesn't replace a test light and a test light doesn't replace a power probe.
Too many minis
PostPosted: Tue Jan 16, 2024 11:18 am
Interesting ..can you explain how or why I would want a "power probe"?
Thanks, Ian
PostPosted: Tue Jan 16, 2024 11:51 am
Maybe I am a budding LUCAS electrics man.
PostPosted: Tue Jan 16, 2024 12:33 pm
Thanks, Ian
It is basically a switch which connects + or - to the probe depending on the switch position.
Lets say you were testing why a headlight is not working. You could use it to provide + to its + terminal then try negative. Then you would do similar at the relay to see if the wiring is good and then try to trigger the relay using the power probe.
It's the same as using piece of wire to temporarily test something. The power probe does have leds to show if what you are touching is - or + so that you don't create a short.
Too many minis
PostPosted: Tue Jan 16, 2024 1:17 pm
Much appreciated... I wondered what it does that my bit of wire with a couple of alligator clips didn't...
PS Cooperess..... you do know that's why Poms drink warm beer ?? :lol:
Various Body Earthing Points and bulbs I am using
PostPosted: Tue Jan 16, 2024 1:30 pm
cooperess wrote:
Hope these help.
I'd be inclined to pull those terminals off and then put them back on (one at a time) and then waggle them to make sure they are all tight on the male terminal. If not gently crush the female to increase the bite. Don't laugh. I had major problems on another vehicle caused by a blade fuse due to the legs being undersized in thickness. A replacement sent to problem packing.
PostPosted: Tue Jan 16, 2024 1:40 pm
It doesn't look like your voltage stabiliser is connected correctly.
Too many minis
PostPosted: Tue Jan 16, 2024 2:46 pm
It was until "Wiring Getting Hot" Doesn't that only make instruments work. If I have no temp or fuel gauge and wires don't get hot, then I've solved it.
PostPosted: Tue Jan 16, 2024 3:02 pm
I have long lost track of what has been done. I noticed it and wanted to make sure you were aware. If you weren't aware then if the wires were connected to the wrong places there could be issues.
Too many minis
PostPosted: Tue Jan 16, 2024 5:01 pm
Might be worth double checking this lead and connection. The big rusty washer may contribute to the issue.
Is the earth lead from the battery serviceable? Adding a jumper lead from the negative post to a good alternative earthing point in the boot would help eliminate that part of the electrical system as the fault.
PostPosted: Tue Jan 16, 2024 10:31 pm
This is the way mine was wired before dis-assembley
PostPosted: Wed Jan 17, 2024 4:51 am
You really can't get it wrong as one pair of terminals are female (Inst), and one set male (Batt).
Users browsing this forum: Bing [Bot] and 100 guests
