It is currently Sun Jun 22, 2025 4:47 pm
 Post subject: WIRING PATHWAY
PostPosted: Tue Dec 12, 2023 4:12 pm
As seen in the photo, there are 2 holes on either side of the central wiring hole.
Are these holes used for wiring and if so what wires are fed though each of the extra holes?
This question is for me rewiring my car following my wiring heat problem which I have yet to solve.
 Post subject: Re: WIRING PATHWAY
PostPosted: Tue Dec 12, 2023 4:22 pm
What is your car? By model and year.
PostPosted: Tue Dec 12, 2023 4:30 pm
They are access holes for a screwdriver from under the parcel shelf to screw the speedo binicall to the bulkhead , not for wiring
PostPosted: Tue Dec 12, 2023 5:07 pm
Mk2 1969
PostPosted: Tue Dec 12, 2023 5:51 pm
Cannot help with the holes but if that is the speedo wiring then with the lamp out of the blue white lampholder then the continuity that you measured on the headlight wire should now be gone.
Cheers Dave.
