It is currently Mon Jun 23, 2025 8:48 am
 Post subject: Installing windscreens
PostPosted: Thu Nov 16, 2023 5:09 pm
I have just finished fitting the rear windscreen.
It isn't a job to look forward to but I found a useful item that seemed to make the job a lot easier. Maybe everyone else knows about this, or has a better idea, but I'm posting this so it might help.
I normally use blunt screwdrivers or paint scrapers but they can, and did, nick the rubber seal.
The tool sold to insert the filler strip does a good job at this - the round section wire is less likely to nick the rubber seal. I also used rubber grease on the seal as the usual detergent solution dries out so quickly.
PostPosted: Thu Nov 16, 2023 6:33 pm
I found that the tool you show bent too easily to be of any use.
But yes to the rubber grease and I use a piece of plastic tongue from flooring boards and file the correct profile I need.
Cheers Dave.
PostPosted: Thu Nov 16, 2023 7:11 pm
Check out this thread. I tried it and it works a treat.
http://www.ausmini.com/forums/viewtopic.php?f=2&t=96127
PostPosted: Thu Nov 16, 2023 8:39 pm
I used body filler applicators (plastic ones). I wonder if tyre fitting paste would be a good solution instead of dishwashing liquid.
Too many minis
Users browsing this forum: Gambo, John Sneddon, ken@miniauto and 92 guests
