It is currently Sun Jun 22, 2025 11:59 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: Gear Knob ID
PostPosted: Mon Nov 13, 2023 4:05 pm
There were two types of the early gear knobs.
The very early (first) type had the thread cut straight into the "bakelite" and were locked on to the lever with a thin hexagonal nut.
The more common second type had the thread cut (as it was first screwed on) into a rubber insert and no lock nut. The theory was it helped damper vibration.
Fully imported built up early Coopers had the first type.
PostPosted: Mon Nov 13, 2023 8:40 pm
Thanks for all the feedback. Are replicas still about for sale?
May try to make one myself and look laser cut options in the market. The challenge will be thr chamfer on thr top insert around the edge i think.
Can anyone tell me are thr blue/white checkers a plastic or gloss paper or card, and is it on the base of the bottom insert?
PostPosted: Mon Nov 13, 2023 9:13 pm
Now here's some information you won't find on Google, but you will find on Page 135 of the Mini Clubman Engineering nDrawings book (which no doubt all fastidious owners have). The proportions of the badge are given there, but it is intersting to know that the letters GT are engraved in the upper insert and are coloured bright red (including the vertical sides of the engraving) while the 1" dia blue check pattern 0.12" dim (described as "blue hot stamped") appears as a separate flat insert underneath. Regards, Tony
PostPosted: Sun Sep 29, 2024 8:09 pm
Well didn't this post lead me down a path over the last 11 months. Ever since my realisation the GT I purchased had a dud gear knob - being told it was original - made me invest in my own design to try replicate the original design.
Behold !!! the final product. Now selling on Facebook Marketplace, or can PM me here.
PostPosted: Wed Nov 06, 2024 7:23 pm
I have an original Clubman GT black gear knob with the GT on top. It's leather bound. My car is in the first 100 from August 71.
Hmm. Having looked into it further I doubt it is original although I was told it was. Pretty sure it's not.
1971 Clubman GT
Users browsing this forum: Bing [Bot] and 100 guests
