It is currently Wed Jun 25, 2025 12:39 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: MK2 ENGINE STALL
PostPosted: Thu Nov 09, 2023 6:10 pm
Thats what I thought
PostPosted: Thu Nov 09, 2023 7:07 pm
Sorry yes, you saw it first. This has to be it. Let's hope.
PostPosted: Thu Nov 09, 2023 7:09 pm
something like this.....
PostPosted: Thu Nov 09, 2023 7:29 pm
Tomorrow if I can remember , I am going to run my car and take the cap off and see what happens and report back
PostPosted: Thu Nov 09, 2023 8:01 pm
OK , couldn't wait till tomorrow
Engine at idle roughly900 / 1000 rpm . no choke .still not up to temp
remove oil cap and idle speeds up as now extra air being allowed into the crankcase and then fluctuates but does not stall
in my non educated , non qualified , self taught backyard tinkerer , I would
as a test , start engine , remove oil cap at the same time some one pulls the choke , if the engine still runs with the choke out , your carby mixture is to lean or you PCV has a problem .
Please note I am not an expert and don't claim to know everything , just saying what I would do
PostPosted: Fri Nov 10, 2023 1:16 pm
I reversed the PCV lid but not difference.
Thank you for all your inputs.
It turns out to be a leak in the power brake hose.
PostPosted: Fri Nov 10, 2023 1:28 pm
Have you checked the one way valve to the brake booster?
PostPosted: Fri Nov 10, 2023 1:53 pm
timmy201 That's my next job but for now the booster is not going to be fitted.
PostPosted: Fri Nov 10, 2023 7:28 pm
Hi Cooperess
Sorry a bit late catching up on reading this engine stall matter.
I had the same issue at one stage with my Mk 2 - it turned out to be a pin hole in the power booster rubber diaphragm.
Replaced the diaphragm and no further issues.
Users browsing this forum: No registered users and 123 guests
