It is currently Tue Jun 24, 2025 11:40 pm
PostPosted: Mon Oct 30, 2023 8:53 am
Does the gasket for the large bulkhead centre blanking plate still exist or will I have to make one?
PostPosted: Tue Oct 31, 2023 9:49 am
Did they have a gasket?
When I removed the plate from my son's 72 clubby it just had mastic behind it.
PostPosted: Tue Oct 31, 2023 10:06 am
Yes they did - I have one I can use as a template but need a couple. Will take picture and post when I get back home.
Rod
PostPosted: Tue Oct 31, 2023 11:34 am
The blanking plate (part HYB3917 for Australia and CZH351 UK) had a gasket (part HYB4076 for Australia and ALA4817 for the UK).
A search on the ALA part number might locate the item from a Mini parts suppliers. Minispares don't list it and Somerford show it as NLA - https://www.somerfordmini.co.uk/catalog ... ds=ala4817
If you plan to make your own you can use the specification and dimensions from the engineering drawing. It shows one version of the material as Rubazote, a trade name for high density rubber cushioning.
Click on image to enlarge, and again to enlarge further.
PostPosted: Tue Oct 31, 2023 9:31 pm
Thanks will give it a go
