It is currently Mon Jun 23, 2025 12:55 pm
 Post subject: New BRG Paint Code?
PostPosted: Fri Oct 20, 2023 7:04 am
Does anyone have the Paint Code for New British Racing Green for a Morris Mini?
Thanks
 Post subject: Re: New BRG Paint Code?
PostPosted: Fri Oct 20, 2023 10:04 am
There’s a lot of information in the How To section, including paint codes.
viewtopic.php?f=25&t=66469
PostPosted: Fri Oct 20, 2023 12:12 pm
I haven't been able to find a New BRG formula.
They changed the formula for BRG and Cedar Green in early 1966.
The colour charts were only updated with the New Cedar Green. It appears they forgot to add the New BRG formula.
BRG and Cedar Green Paint dated 3.2.66, New Cedar and New British Racing Green.jpg
PostPosted: Fri Oct 20, 2023 3:44 pm
Ok, for a respray what paint are they using when New BRG is on the ID tag?
PostPosted: Fri Oct 20, 2023 4:08 pm
At a guess they might be using the standard BRG or colour matching a non faded area of their car. The colours are almost identical but reformulated for durability. New paints do the same thing anyway. They use different tinters to give the same colour.
PostPosted: Fri Oct 20, 2023 4:46 pm
Thanks for your responses
PostPosted: Fri Oct 20, 2023 5:04 pm
gtogreen1969 wrote:
... colour matching a non faded area of their car.
That's what most people do if there is still some original painted area on the body shell. The most convenient is the rear number plate flap as its small enough to take to the paint shop for colour matching, and has both a "faded" side facing out and a hidden "unfaded" side.
PostPosted: Fri Oct 20, 2023 5:13 pm
PPG Paraglaze does BRG. There is an early and late code and the change was in 1964 so if you go with BRG then make sure its the later 0862.
PostPosted: Fri Oct 20, 2023 5:21 pm
Just another thought
If your on Facebook then you might try a chap by the name Ian Thorn. - https://www.facebook.com/groups/4427759 ... 705248803/
I think he has recently repainted his BRG and New BRG cars
PostPosted: Sun Oct 22, 2023 10:18 pm
Ok, so where does the '70 MK2 S colour : Connaught Green 12178 fit in the mix ? I have seen codes GN-18(connaught green) and GN-25(BRG) used for Connaught green.
PostPosted: Sun Oct 22, 2023 11:47 pm
GN-18 and GN-25 are UK colours which are different to ours.
PostPosted: Mon Oct 23, 2023 10:23 am
I thought so. Does anyone know of a ppg/protech paint code for the Australian colour?
PostPosted: Mon Nov 06, 2023 11:01 am
I've just painted Barney Connaught Green (GN18) to match the Cooper Works cars.
Users browsing this forum: Majestic-12 [Bot] and 71 guests
