It is currently Mon Jun 23, 2025 4:06 pm
PostPosted: Sun Sep 17, 2023 3:33 pm
Who makes these EXACT stickers. I need one to replace this rubbish one.
PostPosted: Sun Sep 17, 2023 3:37 pm
https://minisport.com.au/products/dulon ... 963c&_ss=r
PostPosted: Tue Sep 19, 2023 2:30 pm
Hi Cooperess, Did you have any luck with this?
The Minisport ones look a little different.
PostPosted: Tue Sep 19, 2023 4:38 pm
No luck, the ones I have seen do not match the original pictured.
PostPosted: Tue Sep 19, 2023 5:54 pm
geez the rest of your car better be pretty bloody good if you aren't happy with the sticker from Minisport.
PostPosted: Tue Sep 19, 2023 6:21 pm
These appear to be on the foil type label
https://mgspareparts.com.au/products/pa ... s-delivery
PostPosted: Tue Sep 19, 2023 6:52 pm
cooperess - well done on searching high and low for original bits for your car. Some of us, perhaps just a few of us, try very hard to keep the car close to what it would be like today if well looked after and not messed with. Based on what you've posted your restoration is a credit to you. Look forward to seeing it once finished.
PostPosted: Tue Sep 19, 2023 7:18 pm
Wasn't someone on here making them a while back ??
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Tue Sep 19, 2023 8:20 pm
Mine is in a bit better nick - slightly different though ( 3/70 MK2 S) . I can send you a better image if you want to get them made..... PM me if interested.
PostPosted: Tue Sep 19, 2023 10:03 pm
Hi, Did the mk1 S in brg and toga white roof have these stickers.
Mk 1 Cooper S 1965
If you could erase all your mistakes of the past
You would also erase the wisdom of your present
Remember the lesson not the disappointment.
PostPosted: Tue Sep 19, 2023 10:15 pm
Great picture ausdino.
Yes it is foil with sticky stuff on the back timmy201.
I don't think it will be as good as you think winabbey.
PostPosted: Tue Sep 19, 2023 11:25 pm
No the paint stickers started around 4/69 when the ID plates were deleted.
They changed the format a few times so someone reproducing them would have to know what was used at any given date.
The Crystal white had 5 different styles.
PostPosted: Wed Sep 20, 2023 7:58 am
Thank You
Mk 1 Cooper S 1965
PostPosted: Wed Sep 20, 2023 8:00 am
Well done gtogreen1969. That picture also helps me to date my Mk2.
PostPosted: Thu Sep 21, 2023 7:41 pm
The people on this web site just keep on impressing me with the information and photo's that they have to share.
One very big Thank you for all that you do! :-)
