It is currently Sun Jun 22, 2025 1:08 pm
 Post subject: Vacuum point on Manifold
PostPosted: Fri Sep 15, 2023 9:00 am
Hi All
We have fitted disc brakes to our 70 van and they work well, but now we want to fit a booster. The inlet manifold is cast iron and does not have a vacuum point. Did anyone ever produce a single SU manifold with a vacuum point?
Bazzz
Mini Cooper S Mk 2, 1970,
Mini van 1970 with side windows now converted to 4 seater traveller
PostPosted: Fri Sep 15, 2023 9:12 am
The Minispares alloy heated manifold has the booster take off. you do not need to connect the heater pipes.
However I ran with a booster for a while and it makes no difference to disc brakes, in fact the pedal feels better without the booster and the brakes work fine.
Cheers Dave.
PostPosted: Fri Sep 15, 2023 1:24 pm
Which size SU?
I assume HS2 1-1/4
If it was HS4 1-1/2 it would be easy.
Too many minis
PostPosted: Fri Sep 15, 2023 1:29 pm
Could you drill and tap 5/8 UNF and install part number 12H1405 ? Some of the latter manifolds came with tapped hole ie metro
PostPosted: Sat Sep 16, 2023 6:28 am
Hi All
Thanks for advice. We are using a HS2 1-1/4 on the van at present. What is the solution if we did have a HS2 1-1/2 installed 68+86auto?
Drilling and taping a 5/8 UNF thread is an option, but I am not sure about the cast iron manifold holding up.
PostPosted: Sat Sep 16, 2023 7:37 am
It appears there is at least one factory cast manifold HS2 with a booster port - 12A1097. It says Morris Minor but it is also listed on some mini sites
https://www.morrisminorspares.com/engin ... ck-p830325
One option is the alloy type manifold for HS4 and HS6
https://minisport.com.au/products/mini- ... 0963&_ss=r
Then an HS2 adapter
https://minisport.com.au/products/mini- ... 859b&_ss=r
Another option is a Lynx manifold, which would need to be drilled and tapped for the carb studs and booster port if you want to keep HS2
https://www.lynxauto.com.au/mini-850-12 ... 1-3-4.html
PostPosted: Sat Sep 16, 2023 8:22 am
No problem drilling and tapping a cast iron hs2 manifold. Doesn't need to be 5/8 unf though, 1/4 bsp is plenty big enough. Fit a brass barb fitting.
PostPosted: Sat Sep 16, 2023 10:13 pm
bharp831 wrote:
Hi All
The HS4 1-1/2 manifolds used on matics have a manifold vacuum port for the PCV. Because you have a HS2 1-1/4 you could probably just drill and tap your manifold.
Too many minis
PostPosted: Sat Sep 16, 2023 11:22 pm
I wouldnt bother putting a booster on it, buy a really good set of competiton pads and it will stop fine as a rule we dont run boosters on competition cars, neither on rally cars or race cars, it's only the heat range that we change on a rally car run something that works from a lower temperature, on a race car run a higher heat range.....there is much better pedal feel without a booster. personally I run P agid pads but something cheaper like EBC will do the job fine
PostPosted: Sun Sep 17, 2023 8:46 am
I run ebc Greenstuffs on my Mini and my son's, I have a booster now on mine but ran 30 years without one. Stop fine without.
I tried blackstuffs but got brake fade on kurrajong hill and Mt Keira.
Ymmv...
PostPosted: Sun Sep 17, 2023 10:18 am
Are these the pads DP2102?
PostPosted: Sun Sep 17, 2023 11:07 am
Yes.
Were $99 at minisport SA
PostPosted: Mon Sep 18, 2023 1:11 pm
Not sure why but over on the UK mini forum they reckon ebc pads are hopeless.
I have been using them and find them OK, I wonder if enviromental conditions heat humidity etc come into play?
Cheers Dave.
PostPosted: Mon Sep 18, 2023 1:21 pm
They do work better as they warm up, but are fine here even the 1st application cold. Ii think it's the cold crap weather over there.
Also, since 1984? or sooner UK Minis came with 12" wheels, 8.4 discs not our 7.5 S ones. Maybe different pedal feel.
PostPosted: Mon Sep 18, 2023 3:30 pm
The weather can be crap over there, thats one of the reasons I emigrated. The 12 inch wheels may be one thing but they are talk8ng about 7.5 pads mostly.
Cheers Dave.
