It is currently Tue Jun 24, 2025 4:47 pm
 Post subject: Romac Harmonic Balancer
PostPosted: Thu Aug 31, 2023 11:22 am
Hi All
I'm installing a new Romac Harmonic Balancer to a 1969 Cooper S. Unlike the original balancer which has a lock washer to lock the crankshaft bolt to the balancer
the new Romac unit does not. Question: Is there a method of locking the crankshaft bolt to the balancer ?
PostPosted: Thu Aug 31, 2023 11:54 am
Thread locker aka Loctite
Too many minis
PostPosted: Fri Sep 01, 2023 7:41 am
Loctite 262 or 263.
PostPosted: Sat Sep 02, 2023 8:21 pm
Thanks for the replies. Does anyone have experience installing the Romac Harmonic Balancer.
As I have found out that it does not slide nicely onto the crank like the original but is an interference fit.
PostPosted: Sun Sep 03, 2023 8:55 am
Check for burrs on the keyway. Check also the key width if new. Some new keys from God knows where are a few thou too thick.
Balancer should slide on, neat but not interference fit.
I recently fitted 2 to new cranks.
PostPosted: Sun Sep 03, 2023 4:35 pm
Thanks for the info DrMini, did you fit Romac Balancers to the new cranks ?
PostPosted: Mon Sep 04, 2023 7:10 am
Yes.
Before fitting a new key check it slides through the balancer. Rub on 180 paper on a machined surface untit does.
Also try fit the balancer with no key, deburr the crank with 180 paper until it does. Often there's a burr on the crank keyway.
PostPosted: Mon Sep 04, 2023 7:43 pm
What are the advantages over the standard Cooper S balancer (besides age) and would/should you get it balanced when getting crank/flywheel/rotating assemblies balanced ?
PostPosted: Mon Sep 04, 2023 8:38 pm
You can buy them. Balanced by factory.
I don't believe they need balancing when fitted. I've balanced cranks then + flywheel then + backplate then + diaphragm. Can't do harmonic balancer during this as crank nose is driven by the dynamic balancer.
Edited for clarity.
Last edited by drmini in aust on Mon Sep 04, 2023 9:23 pm, edited 2 times in total.
PostPosted: Mon Sep 04, 2023 8:48 pm
Thanks for the heads up.
PostPosted: Mon Sep 04, 2023 11:14 pm
Edited for clarity.
Thanks Dr.
PostPosted: Wed Sep 13, 2023 12:03 pm
I did find fitting it to my engine in-situ it was too tight. There were some marks on the crank nose of my very much used crank, so I had to spend quite some time with emery cloth linishing just the very end to get of the crank to get the new balancer on.
