It is currently Mon Jun 23, 2025 9:21 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Tue Aug 29, 2023 7:30 pm
Online
More thoughts...
1. What diaphragm is it?
Blue? Orange? Grey? Double Grey?
I wouldn't go stronger than an orange one on a road car.
2. There have been coating adhesion problems with some recent ACL thrust washers in packaging marked 'packed in Tasmania. These are a product of China. Contact Graham Russell for further info.
Previous ACL ones said Made in Tasmania.
Edit
What crank? 998 & 1098 have smaller thrusts than 1275s so more psi load when clutch is disengaged.
PostPosted: Tue Aug 29, 2023 7:48 pm
These are the thrust washers I fitted. It’s for an 1100. I guessing they may be the problem then after all.
Also pulled clutch out this afternoon. It’s a blue dot but also worked out that the diaphragm doesn’t sit flat either. Need to take 28 thou off of posts to get it flat. Current thickness of clutch plate is 7.76mm so almost new still.
PostPosted: Tue Aug 29, 2023 8:56 pm
Online
The last 2 1330 motors I helped build we sourced other thrusts.
PostPosted: Wed Aug 30, 2023 7:14 am
Can I ask where from and what brand please?
Pete
PostPosted: Wed Aug 30, 2023 11:13 am
Online
Pete
Will advise when the owner finds records.
I think were GLYCO brand .
Try here https://www.precisionintl.com/products/ebt2204t2gy
Edit check, I think these were for 1098 with 2" mains eg sprite.
Same size as 1275 not yours.
PostPosted: Wed Aug 30, 2023 6:30 pm
Had a talk with Graham Russell today about this issue. He was explaining that the thrust washers that are made in china are a bright bronze colour instead of the dark dull colour of the originals. Also the china one have square ends instead of the rounded ones. We ascertained that i have in fact got the chinese but as it's not a performance build it should be fine to keep them in. Graham has has success with in road motors but has had dramas in race motors. He also stated it is normal for the revs to drop a small amount on small bore motors with a heavyish clutch and also said the new Blue Dot diaphragms are actually stronger than the old ones and not far off of the orange ones.
Anyway I sorted out the diaphragm on mine as it was not sitting flat. Had 30thou taken off of the posts, reassembled it and checked again. It's not perfect but within about 3 thou of being totally flat.
Put it back in and ran it up.
It is heaps better now, revs still drop but only by about 100 rpm. I'm happy with that so it will stay like that for now.
Thanks to all for your help especially drmini and Graham.
Sorry for the long winded response.
Pete
PostPosted: Fri Oct 27, 2023 2:23 am
Hi all,
Bit of an update. We had to pull the engine and box out due to a different issue ( diff pin let go, may have seen my sons post on Facebook about it )
Anyway we checked the thrust washers and they were in the correct way but were about stuffed. Will find pictures later and post.
The engine only had about 500km on it and the thrust material had started to wear excessively. To the point that we had 6 thou end float when built and was out to 7 1/2 thou when we pulled it down.
Found a good set of old ones in the garage and fitted them.
The drop in revs has totally disappeared now, happy days.
These were new ACL thrusts but going by the information available they are the ones made in China. Different colour and no angle where the 2 halves meet.
Try and keep all your old ones as these new ones are crap.
Thanks for all the advice and if GR reads this thank you for your time on the phone.
Pete
PostPosted: Fri Oct 27, 2023 6:36 am
Online
They are supposed to be sintered bronze that's why originals are dark. They are quite hard. I suspect China isn't doing it properly, if at all.
Users browsing this forum: drmini in aust and 74 guests
