It is currently Tue Jun 24, 2025 3:26 pm
PostPosted: Sat Aug 19, 2023 12:45 pm
Hi all, my front subframe previously had hydro suspension and was converted to rubber cones. There was no upper bump stop mounted as yet.
Since the holes on the upper arm are used for shock absorber mounting, I assume the frame tower is drilled to mount the upper bump stop?
Does this sound correct?
Bit of a bummer if it is because my frame is all nice and painted.
PostPosted: Sat Aug 19, 2023 1:36 pm
Mine was also converted by the previous owner and still has the hydro bump stops fitted. I believe the arms are the hydro type as well.
Cheers, Paul.
1970 Morris Mini K
PostPosted: Sat Aug 19, 2023 1:41 pm
Cheers, Paul.
Ok Paul, cheers, so it looks like the shock mount will also mount the bump stop?
PostPosted: Sat Aug 19, 2023 5:10 pm
Yep, that is how it's mounted on mine.
1970 Morris Mini K
PostPosted: Sat Aug 19, 2023 8:08 pm
I believe you’ll just need to drill the holes for the hydro bumpstop open a bit to match the shock mount
PostPosted: Sat Aug 19, 2023 8:18 pm
[THUMBS UP SIGN][THUMBS UP SIGN]
PostPosted: Sun Aug 20, 2023 1:16 pm
When using hydro arms with shocks I drill the bumpstop to 8mm then use an M8x100 socket head cap screw and 2 locknuts. I bush the shock lower to 8mm bore.
Saves drilling the arms out to 3/8, they are bloody hard.
