It is currently Sat Jun 28, 2025 7:50 pm
PostPosted: Wed Jun 15, 2005 5:42 pm
just put the turbo on it like it was designed ben :D haha nah sorry mate im no help got no idea about all this carbi gear,,, id say you need to lean it out with different needle, but best tuned on a dyno with someone with su experiance.
1974 Moke - 998cc
PostPosted: Wed Jun 15, 2005 6:00 pm
I had a similar problem when i first fired my HIF44 up ....
Check the O rings in the choke mechanism ... mine were dry and cracked.. the choke was on FULL all the time ..... nasty...
Good luck, its a bastard to work on too !
J
PostPosted: Wed Jun 15, 2005 7:39 pm
ill have a look tommorow but i think i will have to change needle
PostPosted: Wed Jun 15, 2005 7:47 pm
Changing the needle had ZERO efect on mine....
Same with the Jet (Thanks again, Grant)
unless you are getting it to load up (Driving) there is very little that the Needle does.....
Good luck
J
PostPosted: Wed Jun 15, 2005 7:48 pm
what can be changed to afect fuel air mix is it that screw near the fuel line?
PostPosted: Wed Jun 15, 2005 8:41 pm
Yep..... In (Clockwise) for rich and counter clockwise for lean...
its a BITCH to get to as well ....
J
ps - i THINK thats it.. i ususally have to pop the dashpot off and double check with a vernier (blown braincells.....)
PostPosted: Wed Jun 15, 2005 8:43 pm
thanks for that tommorow should be fun :)
PostPosted: Wed Jun 15, 2005 10:15 pm
Just as a matter of interest, how come you put a turbo carby and manifold on if you aren't interested in the turbo itself?
Jonathan
PostPosted: Thu Jun 16, 2005 7:13 am
im going to eventually put a turbo on too i have the plenium aswell and im looking at a turbo at the moment :)
PostPosted: Sun Jun 19, 2005 4:51 pm
the carby is on and running with airfilter and lcbs and a rc40 and man does it have some more power now bottom end power is a little better , mid is a noticable difference but the top end power is huge :D its so fun to drive also alot smoother and sound measured at a nice 91db at 3000rpm :)
next mod will a 12g295 ported head and corolla rockers :) i think the turbo can wait im really happy with it the way it is :D :D :D :D
PostPosted: Mon Jun 20, 2005 12:59 am
benjamin wrote:
blah blah blah......and corolla rockers......
Hello!!! Looks like I missed a topic on Ausmini. Corolla rockers huh? Time for me to do a search...
PostPosted: Mon Jun 20, 2005 1:03 am
http://www.ausmini.com/forums/viewtopic.php?t=3829&start=0
eediot :roll:
