It is currently Thu Jun 26, 2025 1:22 am
 Post subject: 10AR/A/H engine prefix
PostPosted: Sat Jun 17, 2023 7:05 pm
Hi all,
Anyone got info on a 10/AR/A/H engine prefix. I have search the net with no success.
Thanks Pete
PostPosted: Sat Jun 17, 2023 7:11 pm
They’re listed here for Morris 1100
http://www.elevenhundred.com/enginenum.php
PostPosted: Sat Jun 17, 2023 7:17 pm
Awsome, thanks for that.
PostPosted: Sat Jun 17, 2023 8:11 pm
You realise that is listed as a 1098cc block for an automatic gearbox and requires modifications to use with a manual gearbox.
Just thought I'd mention it.
PostPosted: Sat Jun 17, 2023 8:16 pm
If you want it modded to manual I have the gear to do it.
PostPosted: Sat Jun 17, 2023 8:27 pm
Yes, Dr Mini. I have your "How to" article printed for reference and have done a 1275 block accordingly. Auto blocks have often been overlooked and it's worth the promotional advertisement to remind newcomers.
PostPosted: Sat Jun 17, 2023 9:31 pm
It should have the good head 295 on it too
PostPosted: Sun Jun 18, 2023 7:11 am
No need to search the internet. Just enter 10AR at BMC Knolwedgebase at https://leylandaustralia.com.au/resources.htm
300,000 records on file including part numbers, engine codes, vehicle codes, publications, etc.. Regards, Tony
PostPosted: Mon Jun 19, 2023 10:13 pm
Surely it is still easier to find a manual block. I might eventually convert a manual block to auto to annoy people, I believe it can be done but not so easy.
I am beginning to have a collection of manual parts that I have no use for including blocks.
Too many minis
PostPosted: Tue Jun 20, 2023 9:05 am
You can use the crank from the 10AR in a manual 998 block to convert it to a 1098.
I had a 10AR block in my first mini. I don't think it had been properly converted to manual. It came apart at high speed and took out the entire engine and gearbox. The only salvagable part was the 295 head.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Tue Jun 20, 2023 6:45 pm
It was already on a manual box when we got it. What are the mods i should be looking for? It was fitted with a normal oil pump, I thought they needed a plate under them but this one didn't have one. Had good oil pressure before I pulled it down.
PostPosted: Tue Jun 20, 2023 6:59 pm
This is the guide for 1275 auto to manual, not sure what the difference is to a 998/1100 block
viewtopic.php?f=25&t=90470
PostPosted: Tue Jun 20, 2023 7:39 pm
Thanks, I have read that as well. I'm unsure if there is a difference either.
PostPosted: Tue Jun 20, 2023 9:50 pm
I difference-
Oil pump recess is same depth on 998/1098 manual and automatic. So no spacer needed. You use a standard 998 oil pump.
You still have to extend the oil hole to the pump....
