It is currently Wed Jun 25, 2025 10:13 am
 Post subject: Hex 2 Part Die Tool
PostPosted: Fri Jun 02, 2023 3:42 pm
I was thinking there must be member here that can make a 2 part die that can be used to crimp a Mini brass open barrel bullet. One that you can put in a vice and crimp the wires with out having to buy a propriety $100 plus hand operated clamp.
I would be interested in getting such a tool for my Mini rewire.
 Post subject: Re: Hex 2 Part Die Tool
PostPosted: Fri Jun 02, 2023 4:39 pm
Have you spoken to any of the people who make wiring harnesses for Minis?
PostPosted: Fri Jun 02, 2023 5:10 pm
No but I don't want a harness, just to make repairs or add items.
PostPosted: Fri Jun 02, 2023 5:28 pm
Oh dear. My suggestion was to ask them what they use when making new harnesses!
PostPosted: Fri Jun 02, 2023 7:31 pm
cooperess wrote:
... with out having to buy a propriety $100 plus hand operated clamp.
There are much cheaper ones that will do the job.
https://www.jaycar.com.au/search?text=b ... 3fdc7a188b
https://jaydeeautocables.com.au/collections/tools
PostPosted: Sat Jun 03, 2023 9:09 am
Hi, its very easy to solder them, just a little time and patience.Bruce, who built the entire loom in my rally car , which has about 150 soldered bullet terminals, showed me how. IMHO, those brass terminals are brittle, and some will split if you crimp them enough. cheers Lindsay
1959 Austin A40 Farina fun car
1965 Mk1 Cooper S restored
1970 Colt 1100F SS restored
2014 Mitsubishi Imiev fully electric daily driver
1948 Allard M coupe Olds 215 v8 project
1971 Twin cam Escort ex Uk championship winning rally car project
PostPosted: Sat Jun 03, 2023 9:35 am
Thanks for the heads up Lindsay
PostPosted: Sat Jun 03, 2023 6:25 pm
I used to use the brass bullet solder type connectors until I exhausted my supply. I inherited a few from my Dad years ago.
Lately I have used the crimp type with the tool shown. The crimping tool cost around $20 on eBay. I feel the brass ones make a better connection.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Sat Jun 03, 2023 7:20 pm
I have used those but they are too long and could short out.
PostPosted: Sat Jun 03, 2023 9:21 pm
I bought one of these sets and this crimper. I had many of them snap in two and many crimp failures, I had assumed it was either the crimp tool or me.
I do have some of the open barrel type Lucas sized bullets but I haven't liked using them as they need an additional boot otherwise the terminal is exposed and can contact other stuff as has been mentioned already.
I am thinking in the future for anything that doesn't need to be original I will switch to Japanese type bullets to save cost and they are easier to get.
Too many minis
PostPosted: Sun Jun 04, 2023 12:22 pm
Here is what is causing me to look for a more original way of joining wires.
PostPosted: Sun Jun 04, 2023 12:43 pm
Protecting metal extremities is the role of heat shrink tubing.
https://jaydeeautocables.com.au/product ... 75f9&_ss=r
PostPosted: Sun Jun 04, 2023 12:57 pm
PostPosted: Sun Jun 04, 2023 12:58 pm
Mini's didn't use heat shrink, did they!
PostPosted: Sun Jun 04, 2023 1:05 pm
No, but I thought you compromising because of the issues you are having.
Users browsing this forum: Hobson and 95 guests
