It is currently Sat Jun 21, 2025 2:56 am
PostPosted: Tue May 02, 2023 3:11 pm
Hi team , looking for some advise/tricks on fitment of sliding window doors on a Mini K shell , I am using correct seals obtained from Karcraft , but can't get the dam things to close correctly .
No issue when I remove seals , with equal clearance between shell and doors , well as close as I could get it :-)
Thanks in advance
Cheers Mal
PostPosted: Tue May 02, 2023 4:58 pm
Have a look at this long thread on door seals. In the link below I've fast-forwarded to the current area of interest which is remaking the original style.
viewtopic.php?f=2&t=84464&start=75#p1068458
PostPosted: Tue May 02, 2023 5:00 pm
The area around the lock mechanism on the B pillar is slightly different for sliding versus wind-up windows doors. Someone with knowledge may be able to comment.
PostPosted: Sun May 07, 2023 11:20 am
I brought 850 door seals in from UK and tried to use them on my 1970 matic, same shell as a K. Had a 3mm gap from door to body. Oz windup door rubbers are wider and fitted properly. You need proper 850 ones.
