It is currently Wed Jun 25, 2025 12:19 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2, 3  Next
PostPosted: Thu Apr 20, 2023 6:22 pm
I cannot for the life of me get this thing working and have come to the conclusion that it's a dodgy stalk. I have had this stalk for quite a few years and was bought brand new. Only the passenger side indicator will work but the drivers only gets a very dull light both with a circuit tester and on the car itself. I've pulled it apart cleaned the contact points but still does the same thing. Fine with the passenger drivers has the faintest power transfer. Is this a dodgy stalk or am I missing something ?
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Thu Apr 20, 2023 6:32 pm
If it’s same problem as I had, it could be the connectors under the dash where they join from the stalk into the harness. Mine had badly crimped bullet connectors from the stalk harness that caused me enormous grief until I realised they were the culprit. This is especially so if the stalk has been replaced at some time.
PostPosted: Thu Apr 20, 2023 6:37 pm
Try installing a temporary earth from one the right hand rear light fixture mounting studs to the battery earth. Does that improve things?
PostPosted: Thu Apr 20, 2023 7:15 pm
Clip thanks for the reply. The wire isn't even going active apart from the tinest bit. If it were the same problem as you had the wire coming out of that Junction would be dull one end and bright the other? It's not even bright at the indicator stalk. DavidE I have 2 tanks in so will have to pull one out to check this. If it's the case what would the issue be ?
1970 mini k
1975 leyland
PostPosted: Thu Apr 20, 2023 8:54 pm
A poor earth because the securing nuts/split washers haven't bitten into the metal. Try a short jumper wire with a baby alligator clip on the difficult end.
PostPosted: Thu Apr 20, 2023 9:04 pm
I'll keep yous posted. You mean on the tail light stud?
1970 mini k
1975 leyland
PostPosted: Thu Apr 20, 2023 11:15 pm
Cheap Chinese Lucas?
PostPosted: Fri Apr 21, 2023 8:04 am
Yes.
PostPosted: Fri Apr 21, 2023 4:36 pm
The earth on the stud didn't do anything. I'm not sure whether a Chinese or not. I'd assume so. So im thinking odgy stalk
1970 mini k
1975 leyland
PostPosted: Fri Apr 21, 2023 5:15 pm
I did buy a new stalk a few years back, but had to cannabalise the old one to get enough good parts to make the new one work.
PostPosted: Fri Apr 21, 2023 6:14 pm
Just annoys me so much. Was bought as a gift years ago to go towards my resto. Finally come to use it and it's no good......another 200 odd bucks for a new one I suppose...
1970 mini k
1975 leyland
PostPosted: Fri Apr 21, 2023 6:15 pm
Since it sounds like there is poor contact in the switch somewhere how are the cables connected to the contacts of the switch? It might be worth soldering the connection as it could be loose.
Too many minis
PostPosted: Fri Apr 21, 2023 6:50 pm
All wires on the stalk are tight. I have pulled it apart cleaned the brass/copper? Terminals and it still doesn't change things. Even the two little fingers don't go properly active when pushed to that side. However the other is fine.
1970 mini k
1975 leyland
PostPosted: Fri Apr 21, 2023 8:54 pm
Sounds like a poor connection or broken wire.
Use a test lamp with power to the supply of the stalk and move the probe of the test lamp along to determine where the break/high resistance is.
Phil
PostPosted: Sat Apr 22, 2023 10:00 pm
i did what you said Phil and still the same result. the light in the tester even goes dull
1970 mini k
1975 leyland
Users browsing this forum: timmy201 and 99 guests
