It is currently Wed Jun 25, 2025 7:42 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
 Post subject: Re: 2 piece head lining
PostPosted: Tue Feb 28, 2023 8:37 am
1071 S wrote:
Each of the two piece frames has an outer perimeter and cross pieces. They just sit (tightly) on top of the cant rails. You hold each piece towards the middle, bow the centre rod downwards and then slide each piece forward or backwards as applicable. When you release the bow, spring tension holds it all in place.
Although, I have seen cars with a small Phillips head screw though the rear corners of the front piece into the cant rail.
Cheers, Ian
That’s how mine works with the two screws either side at the rear of the front section. Bit of a bugger to fit to be honest, but maybe not as hard as the one piece?
PostPosted: Wed Mar 01, 2023 4:56 am
I have I think 2 frame sets that I don’t really need
Haven’t looked at them for some time but I think they are serviceable
Wayne
Users browsing this forum: bharp831 and 95 guests
