It is currently Wed Jun 25, 2025 6:48 pm
 Post subject: Electrical Advice
PostPosted: Tue Feb 21, 2023 5:03 pm
My 1969 Mini is running an old Lucas alternator. When engine is idling and I turn on the headlights the revs drop, then I turn on the high beam and the revs drop more. Is there a problem and if so please how is it fixed?
 Post subject: Re: Electrical Advice
PostPosted: Tue Feb 21, 2023 5:35 pm
Theoretically, this is quite logical. At idle the engine is producing juuust enough power to match the load imposed by engine friction. If the battery is depleted (by cranking the motor to start) then a bit more load is introduced and something has to compensate... more advance or perhaps some extra fuel???
More load (ie lights - my high beams consume about 1/3 hp - by my mental arithmetic - happy to be corrected). More load = more vacuum = more fuel (unless you have vac advance which may partly compensate???
If the mixture can't compensate then revs must fall (less revs = less friction = less load)???
Laws of physics prevail....
If you have bad wiring/ connections then heat (more load) is being generated......
Have you tried blipping the throttle ...do the lights get brighter???
Cheers, Ian
PostPosted: Tue Feb 21, 2023 6:11 pm
That sounds like a normal functioning alternator to me.
The higher the demand on the alternator, the higher the effort will be to spin it. I like to have my idle a little high, so the times when you’re driving at night with the wipers on it still has a decent idle
PostPosted: Wed Feb 22, 2023 2:02 pm
I guess I am used to modern cars which are more better at these things.
PostPosted: Wed Feb 22, 2023 2:22 pm
Modern cars have ignition control, electronic throttles or idle air control valves that regulate the idle speed.
PostPosted: Sat Feb 25, 2023 1:02 pm
Simplest is to turn the idle speed up a bit
You could install a new alternator, they are more efficient
Users browsing this forum: BBY755, MINI66 and 88 guests
